Bought the 3.73's from you folks early last year; hard to imagine driving the Magnum without it now...thanks!
Printable View
Ted, I know that uping to 3.06 isn't that much, but is it offered in the 2.82? Also, what is the HP rating these can handle?
No, it is not offered in a 2.82. Actually going up to a 3.06 is a nice change. We did one here at our shop for a customer who said it was a night and day difference. It really woke his Charger up!
As for HP ratings, this is still a grey area as not enough testing has been done. With the upcoming racing season, I sure we will find out more info on the units. We have seen many of these behind stroker motor applications that have been holding up quite well.
Did they give you an answer yet?
I asked them and they told me no only if and when updating was needed and didnt expect it to be soon. I was really hopeing to go to the 3.73.
Cant drive my car anymore, diff finally gave out. I will be ordering the 3.06 LSD conversion kit hopefully next friday the 12th.
They have not responded as of yet. I called Diablosport to request this to be added. I was told to post the request in their forum, and it would be added to their next release.
Ted,
I ordered this kit for a supercharged 07 SET Charger.The kit works great and with the 3.73. gears it is ridiculous.I would like to add that I had to install two shims under the diff bolt that is vertical (the supplied longer bolt.) This will eliminate the diff from touching the sub frame. If the diff touches even slightly it will transfer the sound right into the cab. I added these after the install the sound difference was astounding.
Make sure the axles are properly seated into the diff. It will be clunky if not set into the diff!!!
http://www.youtube.com/watch?v=_6a-xh4hvC4
http://www.youtube.com/watch?v=KHaX-f8exFM
Nice videos.
I wish I could install the diffs in less than 10 minutes!!!
My new 3.91 should be delivered tomorrow. I can't wait to get this installed.
Do the 09 and newer axels come in 215mm or strictly 226mm?
