Results 1 to 15 of 24
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    Welded Rear Ends
    OK, SO most people I talk to about this are ether 100% No or 100% hell ya.
    I have some good boy that tell me they drive the Chevys every day with a welded rear and it causes them no gref, except during hard 90 degree turns. In wich the rear tire will skipp and make a screaching noise.
    One of them has is 07 corvett rear welded and took me for a ride, it did not seem bad, It only made the sound one time while trying to make a sharp parking turn.
    I know it can cause more stress on the rear parts, but will DSS axles Im not to concerned.
    Has anyone done this in a LX????
    Im willing to weld my SRT8 rear up, while haveing my gears installed, but I would like to have a spair open diff locker (insides) just incase I don't like it.
    Please include your exsperance, I know some will say get the 09 getrack, or a $1200 quaife, or a $$$$ Locker, but I already have DSS axles and I am not going to speend that kind of cash for a rear locker!!!!
    SO if you have some experaces or something isitefull please let us all in.
    Thanks IRON MIKE
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
    gsjoe's Avatar
    gsjoe is offline You talk'n ta me?
    Feb 2005
    st louis area
    Try backing out of your driveway and turn out to pull away. It may tend to go straight.
    highly difficult to turn when backing
    MSRT8
    Zoomers exaust, CFAH intake, Inertia ported with spartan max cam, predator w tune
    CSRT4
    Zoomers exaust, mopar s1, driver mod box, scan gauge
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Don't weld the rear......especially on the street.There are guys with much more power running on open differentials with no issues.A spool is not necessary.
    BFNY PERFORMANCE
    RIP My Friend
    Adanac Charger's Avatar
    Adanac Charger is offline It's a family sedan... Hang on kids!
    Brooklin, Ontario, Canada
    Imagine going 60mph down a country road in the rain... You go around a corner and your rear end passes you...
    ... Or you could weld your diff into a spool and experience it.
    Not a good idea. Either the inside wheel has to spin a bit to keep up with the outside wheel, or the outside wheel has to skid a bit to slow down to the speed of the inside wheel. Either way, you don't want it happening around a corner in the rain.
    2006 Charger R/T with Road & Track .-- .Bright Silver
    PWR 419 / Eagle Heads / Fr-230 Cam / MM Ported Intake / C&L CAI / PI 2800 TC / Paramount Valve Body / ATI Flexplate
    Joelvan Rad / Police Oil Cooler / HalfFast B&M Tranny Cooler / CTP DS Loop / SLP Line Lock / Getrag 3.73 / Brembos / 20" Forged Alcoas... and a bunch of other schtuff .
    In the mail... .PWR Apache heads, PWR Fr-240 cam, ARH headers, SpeedRated FTI 3800 TC, Mopar 6.4 fuel pump
    Awesome install by HalfFast Performance !! . . Awesome tune by JerseyBoy !!
    Aug 2008
    Wichita, Ks.
    I had a 72 Pontiac LeMans with built 455 and a welded rear end. The car ran high 12's with a 3.07 gear and a TH350 w3k stall. Worked great at the track but drove me nuts on the street with wheel hop. The rear end finally broke on the street. It might not be as bad with the independant rear, but I wouldn't do it.
    E85, 226LSD3.06, PT3800BS
    12.59 @ 113 4350# on M&H325s
    Redfox0099's Avatar
    North Charleston, SC
    Didn't some one try it already and it broke the 1st track day?
    Posted via LXFMobile
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Quote Originally Posted by Redfox0099 View Post
    SRTHardware?
    gsjoe's Avatar
    Feb 2005
    st louis area
    parking would be very difficult.
    MSRT8
    CSRT4
    srt-hardware's Avatar
    srt-hardware is offline Fast is the game
    Jan 2007
    Upstate NY
    Yep, I did it
    Still have it in the garage
    But never drove far on the street.
    It was an experiment before we had DSS axles. I wanted to see if we sent the power to both wheels equally then maybe the axles would hold up, since I had already broken 2 at $300 a pop. 2nd or third launch I still broke an axle. Good news was that I was able to drive off the track under my own power.
    As far as using it on the street, it depends on how you will use the car. If you drive it daily then it will probably tick you off. The tires will skip every once in a while for any diff in wheel diameter and Slalom driving will be horrible. Good news is that that the tires will make lots of screeching sounds which will make the car sound faster to others and donuts will be more fun. What is your intended purpose?
    My Mods:
    Procharger F1-C supercharger @ 15psi running thru a full custom ductwork including a Danko productions Shaker hood kit transformed into THE FAKER SHAKER you see today by 402 Motoring and a 24"X18"X4" air to air intercooler then to the throat of a single plane intake by XV Motorsports, 8.5:1 Comp ratio, H-beam rods, Ross racing pistons, P&P heads & intake, Diablo tuned by Dave @ B&G, complete return fuel system using a Weldon racing pump and pressure regulator, Methanol injection removed, Nitrous perimeter plate capable of 100-300hp (at 175 now), RUNNING 10'S ON THE DRAGSTRIP
    DodgeDude99's Avatar
    DodgeDude99 is offline LX Padiwan
    Lincoln Lockers are definetly not for the street.
    not only will you get the massive understeer, but say you road race, take the twisties, or what not, that inside tire of the turn you are trying to make will get alot of wear since it will be spinning at the same speed as the outside tire, open diff, LSD, or a regular locker it doesnt do it.
    then there is the issue of the durability of the welded spiders. being the spiders were in gear lube for quite some time, the odds of you getting them totally clean to make a good weld is slim as weld.
    then when the spiders do let go, they are going to take that nice and expensive R&P set with it.
    now if you have an offroad truck, weld away.
    Columbus Ohio
    Quote Originally Posted by srt-hardware View Post
    Yep, I did it
    You want to sell it????
    I know there are car faster than mine, with more power.........
    But I have my car camed diffrent than most, Know that I fixed it, I have tons of TQ down low, and for me my race is won with the 60fts.
    I just upgreaded to the M&H 28in tall drags and the best I was able to get was a 1.66 60 FT and that was off ideal and SLOWLY giveing it gas, I would love to be able to stall her up, or punch it harder but she never hooks, tired all the tricks, air ........
    Im sure I will have to get the 28in tall slicks from Hossier, but there has to be away to hit harder off the line.
    On the street, Im sick of my cars rear end jumping side to side depeding on wich tire currenitly has trackshion.
    Adanac Charger, I stugle with tracshion daily on the street, haveing my rear all over the place in the rain is no new thing for me.
    I ant Scarred,
    I my M109R Bullavard is my daily driver anyway.
    Frank Racing Inc
    Best Run to Date...
    65standard's Avatar
    65standard is offline Programmer/Fabricator
    Dec 2008
    Chicagoland
    I ran a spool on the street for a month or so. Then I broke an axle after backng out of the driveway. Got another Moser axle and broke it again. I finally wised up and swapped in a detroit locker.
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    Just curious why do you think welding it up is gonna help you that much with traction?
    Columbus Ohio
    You said haveing a posi helpped you right????
    I know thats a loaded question. LOL
    Im just looking for ideals how I can launch like the GTO guys.
    Frank Racing Inc
    Best Run to Date...
    [quote=1362#Sublime;2163092]You want to sell it????
    quote]
    yes but there is a bit of difference between having your rear end kick side to side as you are trying to drive then there is having a spin out while taking a turn, or hav the car turn 90 degrees as you try to leave a stop light.
    i know its a truck with mud tires, but this was a common occurences with my K5 when i first got it that the previous owner "installed". a locker can even be squirrelly on the street in the rain if you dont pay attention.
