Results 1 to 5 of 5
    imperigal is offline LX Newbie
    Apr 2009
    Transmission Problems with my "new" Magnum!
    Normally, I don't buy cars from dealerships because I have the belief that they'll cobble things together just well enough to fool the un-knowing buyer, only to have the problem reappear once the "as-is" sale is complete. I'm not saying 100% that that's what happened to me, but I sure as heck was dissappointed with how much the dealer (Texas Direct Auto in TX) misrepresented the fact that there was OBVIOUS paint work done to the car. I had already purchased the car and still wanted it cause it was at a good price, so there was not too much I could do about it. The car ran and drove well and I've heard nothing bad about the engine/tranny combo in the Magnums/300s, etc.
    I left TX last Friday and made it back to Michigan by Sunday afternoon. No problems. However, I noticed a slight "fluttering" in the trans when shifting from reverse into drive on Tuesday. Then on Wednesday I noticed a few more funny shifts.... nothing too bad, but my ears perked up. On Thursday... that's a different story. I was driving up Gratiot to work and when shifting from 2nd into 3rd it made a bad noise (heard and felt it). I could NOT get it to produce the sound again! So now, I am watching/feeling it like a hawk and notice that it shifts into 2nd much fast than it should (which it wasn't doing before). I thought perhaps "limp-in" mode, but that wouldn't make sense.
    Any ideas???? Besides fluid, what else can I check? No leaks anywhere, level looks good. Any help would be appreciated greatly!!
    Christine
    2008 Magnum R/T (silver with all the options and Road & Track pkg)
    1970 Plymouth Sport Fury
    (yes, I actually work on cars, actively pursue old Mopars and have a respectable tool collection)
    NC-SXT's Avatar
    NC Coast
    When you say the level is good, how did you check it? These dont have transmission sticks. How many miles since a trans flush?
    WWW.DodgeMagnumGrille.com
    Apr 2009
    Ok - more accurately - dealer said level was checked and good. So, I should probably not assume that it's true! I don't know if it's ever had a trans flush. Could it be something as simple as that? How would I check thie fluid level? Would it be something similar to checking the fluid in a transfer case?
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Quote Originally Posted by imperigal View Post
    If you query this forum you will find the fluid level charts and the dipstick is a Miller tool 9336 at about $70 or make your own using one from a Ram truck that is around 46" in length. Only about 39" is really needed. Mark the end at 10mm increments up to 70mm.
    Then use the fill level chart to get the right level. The chart is based on temp of the trans fluid. If you have about 55mm to 65mm of fluid and the engine is at operating temp you should be good or at least close, but if you have more or less than I would get it corrected.
    Here is most of the service TSB but the images will not copy over. Remember the chart has been posted here somewhere just need to look for it.
    FLUID AND FILTER
    DESCRIPTION
    The oil level control is located on the electrohydraulic
    unit (4) and consists of the float (5) which is integrated
    into the electrohydraulic unit. The float is positioned to
    plug the opening (6) between the oil gallery (2) and
    gearset chamber (1) so that the rotating gearsets do
    not splash about in oil as the oil level rises. The oil
    level control reduces power loss and prevents oil from
    being thrown out of the transmission housing at high
    oil temperatures.
    OPERATION
    With low oil levels, the lubricating oil which flows constantly
    out of the gearset, flows back to oil gallery (2)
    though the opening (6). If the oil level rises, the oil
    presses the float (5) against the housing opening (6).
    The float (5) therefore separates the oil gallery (2)
    from the gearset chamber (1). The lubricating oil which
    continues to flow out of the gearsets is thrown against
    the housing wall, incorporated by the rotating parts
    and flows back into the oil gallery (2) through the
    upper opening (arrow).
    LX AUTOMATIC TRANSMISSION NAG1 - SERVICE INFORMATION 21 - 379
    DIAGNOSIS AND TESTING
    EFFECTS OF INCORRECT FLUID LEVEL
    A low fluid level allows the pump to take in air along with the fluid. Air in the fluid will cause fluid pressures to be
    low and develop slower than normal. If the transmission is overfilled, the gears churn the fluid into foam. This aerates
    the fluid and causing the same conditions occurring with a low level. In either case, air bubbles cause fluid
    overheating, oxidation, and varnish buildup which interferes with valve and clutch operation. Foaming also causes
    fluid expansion which can result in fluid overflow from the transmission vent or fill tube. Fluid overflow can easily be
    mistaken for a leak if inspection is not careful.
    CAUSES OF BURNT FLUID
    Burnt, discolored fluid is a result of overheating which has three primary causes.
    1. Internal clutch slippage, usually caused by low line pressure, inadequate clutch apply pressure, or clutch seal
    failure.
    2. A result of restricted fluid flow through the main and/or auxiliary cooler. This condition is usually the result of
    a faulty or improperly installed drainback valve, a damaged oil cooler, or severe restrictions in the coolers and
    lines caused by debris or kinked lines.
    3. Heavy duty operation with a vehicle not properly equipped for this type of operation. Trailer towing or similar
    high load operation will overheat the transmission fluid if the vehicle is improperly equipped. Such vehicles should
    have an auxiliary transmission fluid cooler, a heavy duty cooling system, and the engine/axle ratio combination
    needed to handle heavy loads.
    FLUID CONTAMINATION
    Transmission fluid contamination is generally a result of:
    • adding incorrect fluid
    • failure to clean dipstick and fill tube when checking level
    • engine coolant entering the fluid
    • internal failure that generates debris
    • overheat that generates sludge (fluid breakdown)
    • failure to replace contaminated converter after repair
    The use of non-recommended fluids can result in transmission failure. The usual results are erratic shifts, slippage,
    abnormal wear and eventual failure due to fluid breakdown and sludge formation. Avoid this condition by using recommended
    fluids only.
    The dipstick cap and fill tube should be wiped clean before checking fluid level. Dirt, grease and other foreign material
    on the cap and tube could fall into the tube if not removed beforehand. Take the time to wipe the cap and tube
    clean before withdrawing the dipstick.
    Engine coolant in the transmission fluid is generally caused by a cooler malfunction. The only remedy is to replace
    the radiator as the cooler in the radiator is not a serviceable part. If coolant has circulated through the transmission,
    an overhaul is necessary.
    The torque converter should be replaced whenever a failure generates sludge and debris. This is necessary
    because normal converter flushing procedures will not remove all contaminants.
    STANDARD PROCEDURE
    CHECK OIL LEVEL
    1. Verify that the vehicle is parked on a level surface.
    2. Remove the dipstick tube cap.
    WARNING: Risk of accident from vehicle starting off by itself when engine running. Risk of injury from contusions
    and burns if you insert your hands into the engine when it is started or when it is running. Secure
    vehicle to prevent it from moving off by itself. Wear properly fastened and close-fitting work clothes. Do not
    touch hot or rotating parts.
    3. Actuate the service brake. Start engine and let it run at idle speed in selector lever position P.
    21 - 380 AUTOMATIC TRANSMISSION NAG1 - SERVICE INFORMATION LX
    4. Shift through the transmission modes several times with the vehicle stationary and the engine idling
    5. Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil
    Dipstick 9336 into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil
    level, repeat if necessary.
    NOTE: The dipstick will protrude from the fill tube when installed.
    6. Check transmission oil temperature using the appropriate scan tool.
    NOTE: The true transmission oil temperature can only be read by a scan tool in REVERSE or any forward
    gear position. (Refer to 21 - AUTOMATIC TRANSMISSION- NAG1/TRANSMISSION TEMPERATURE SENSOR/
    PARK-NEUTRAL SWITCH - OPERATION)
    7. The transmission Oil Dipstick 9336 has indicator marks every 10mm. Determine the height of the oil level on the
    dipstick and using the height, the transmission temperature, and the Transmission Fluid Graph, determine if the
    transmission oil level is correct.
    8. Add or remove oil as necessary and recheck the oil level.
    9. Once the oil level is correct, install the dipstick tube cap.
    TRANSMISSION FILL
    To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
    3. Add following initial quantity of Mopar ATF +4, Automatic Transmission Fluid, to the transmission:
    a. If only fluid and filter were changed, add 7.0 L (7.4 qts.) of transmission fluid to transmission.
    NAG1 Transmission Fill Graph
    LX AUTOMATIC TRANSMISSION NAG1 - SERVICE INFORMATION 21 - 381
    b. If the transmission was completely overhauled or the torque converter was replaced or drained, add 8.1 L
    (17.1 pts.) of transmission fluid to transmission.
    4. Check the transmission fluid (Refer to 21 - TRANSMISSION/AUTOMATIC - NAG1/FLUID AND FILTER - STANDARD
    PROCEDURE - CHECK OIL LEVEL) and adjust as required.
    FLUID/FILTER SERVICE
    1. Run the engine until the transmission oil reaches
    operating temperature.
    2. Raise and support vehicle.
    3. Remove the bolts (5) and retainers (4) holding the
    oil pan to the transmission.
    4. Remove the transmission oil pan (3) and gasket (2)
    from the transmission.
    5. Remove the transmission oil filter (1) and o-ring
    from the electrohydraulic control unit.
    6. Clean the inside of the oil pan (3) of any debris.
    Inspect the oil pan gasket (2) and replace if necessary.
    7. Install a new oil filter (1) and o-ring into the electrohydraulic
    control unit.
    8. Install the oil pan (3) and gasket (2) onto the transmission.
    9. Install the oil pan bolts (5) and retainers (4). Torque
    the bolts to 8 N·m (70 in.lbs.).
    10. Lower the vehicle and add (4.0 qts.) of
    transmission fluid to the transmission.
    11. Check the oil level (Refer to 21 - TRANSMISSION/
    AUTOMATIC - NAG1/FLUID AND FILTER - STANDARD PROCEDURE - CHECK OIL LEVEL).
    Fluid/Filter Service Points
    1 - OIL FILTER
    2 - OIL PAN GASKET
    3 - OIL PAN
    4 - RETAINER
    5 - BOLT
    21 - 382 AUTOMATIC TRANSMISSION NAG1 - SERVICE INFORMATION LX
    Shelby's Avatar
    Shelby is offline LX Padiwan
    Jan 2006
    A 2008 should not have issues- it is relatively new and should be low miles. It should be under warranty.
    2005 vehicles had the leaking seal on the dipstick tube- that led to water from the A/C in the transmission. This should not be an issue on a 2008.
    It does not sound right.
