Results 1 to 15 of 20
    Alcharger's Avatar
    Alcharger is offline Just another 11 second 5.7L Lx
    Birmingham, AL
    Trans Fluid Level Question
    My stall torque converter installer gave me the dip stick he used to set the fluid level without any temperature sensors. I've wanted to check the level and my wife gave me a Dashhawk for my birthday, she knows how to keep her man happy. To my surprise the dip stick he gave me didn't go to the bottom of the trans.
    Today I picked up a dip stick from a junk yard full size van, marked it off at 10 mm increments and pushed it to what I thought was the bottom. It went in easy then hit an elbow or something then went in further. It was not clear that I was at the bottom. This dip stick is about 120 mm long.
    So, it measured about 55 mm at about 170*F. The chart level chart showed it should have been at 65 mm.
    Does 55 mm sound right? How low does the trans have to be before it goes into limp mode?
    I concerned about filling it up to 65 mm and blowing a seal.
    Last question, about how much fluid is needed to raise the level 10 cm?
    Side note, it's interesting that this chart is both metric and English units.
    http://dynamicgrounding.com
    Perfection is not attainable, but if we chase perfection we can catch excellence.
    Vince Lombardi
    PWR ported intake, heads, cam and forged 5.7 http://pwr/parts.com Tuned by Mike Doban at OSTDyno http://www.ostdyno.com
    11.37 ET, 118.4 MPH, 1.50 60', 3940 # RW at -100 DA
    JBs_300c is offline LX Padiwan
    Aug 2007
    alabama
    i need to borrow that dashhawk! lol
    just remember its a lot easier to add than it is to take away. if anything run by the dealer and tell them you thought you seen some tranny fluid under the car you want them to check, should be free
    09 Challenger stone white R/T auto
    Mods:Diablo, Whipple twin screw, Doug Thorley long tube headers, SRT MBRP exhaust, catch can, 180* thermostat, 28x10 hoosier slicks on cobra wheels, .25 fan mod,
    waiting to be installed:
    PI stall converter, new tranny
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Did you have the car in gear when you checked the temp with the dashhawk? Seem to remember reading that it reads engine temp until you put it in gear.
    Alcharger's Avatar
    Birmingham, AL
    Not the entire time.
    I'll try it in gear.
    Vince Lombardi
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Should be ok to take the temp in gear, put it back in neutral so you don't get run over and then take the level as long as you do it right away.
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    yup cant read temp unless it's in gear
    I'll keep my money, guns, and freedom, you can keep the change.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Hasn't posted in almost an hour... he must be run over...
    Nov 2007
    Quote Originally Posted by GasGunR View Post
    LOL ummm wait maybe that's not funny
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    I'll reserve judgement
    Aug 2007
    alabama
    dibs on teh dashhawk just encase your right
    Alcharger's Avatar
    Birmingham, AL
    No luck no getting the Dashhawk, I'm still alive. lol
    Yep, I cycled in and out of gear, temp was 170*F, 45 mm is what I measured and the chart says 55 mm. I'm still not convinced that the did stick is long enough.
    Any know know or have a dip stick tell me how long it needs to be?
    Thanks
    Quote Originally Posted by JBs_300c View Post
    Vince Lombardi
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    I know the ram pickup dipstick is about 2" too long....as far as the actual length I never measured it once it was trimmed.
    BFNY PERFORMANCE
    RIP My Friend
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Quote Originally Posted by Alcharger View Post
    The others are right in that if using the dashHawk to read the temp the trans needs to be in drive or reverse. Otherwise it will read the coolant temp. 55 mm is ok to run but if the chart indicates the level should be 65 mm @ 170 degrees then I would add a little fluid 4-8 onces at a time. It helps to shift the trans through the gears and then recheck. It's very easy to over fill and a PITA to remove. These trans have a float system and don't like to overfilled. If you do a trans fluid change you should be able to put in 4 quarts and start from there. I just finished flushing my trans due to water intursion via a bad filler tube gromet and causing the trans to shudder. As per the TSB I bought 13 qts of ATF+4, a new pan gasket although it is re-useable, filter and ATF-RTV for $102.58
    Then I put in a pint of Seafoam Trans Tune drove it for 30 minutes and started the flushing of the trans by draining and adding 4 qts and draining again. You get the picture. That seafoam trans tune will clean the internals of these trans very good.
    No more shudder and she shifts great know.
    Good Luck
    Alcharger's Avatar
    Birmingham, AL
    Quote Originally Posted by Popeye's Hemi View Post
    Good Luck
    I read about your water in the trans PITA deal. Thanks for the info, I'll put in gear, note the temp, take out of gear and read the level and add 4 to 8 oz at a time.
    When we put in the noids or valve body I'll get some Seafoam Trans Cleaner.
    Glad you got yours fixed before needing a new tranny.
    Vince Lombardi
    Aug 2007
    alabama
    my dip stick is 46" long, when i bottom it out it leaves right at 13 1/2" left, so i guess 32 1/2" would be the smallest you could go.
