Results 1 to 5 of 5
    QuickRT2SRT's Avatar
    QuickRT2SRT is offline Old School drivin' New School HEMI
    Nov 2008
    Independence MO
    tool for drain & fill plugs on 215mm diff?
    Does anyone know the size hex needed for the drain and fill plugs on the SRT 215mm differential?
    2007 Charger R/T - 5.7L Hemi Registry #1055 w/ username QuickRT - Gone/Traded on SRT8
    07 Torred Charger SRT8 - 6.1L Hemi Registry #1151 Mods:
    Predator Modified 93CAI tune, AirRaid SRT8 CAI, Mopar/Corsa CatBack, AMG Paddle Shifters, 4128 t'stat, BT Catch Can, ChillyMod, More to come...
    PB 1/4 ET 12.708 @ 109.10 1.95 60'
    ____________
    Nov 2008
    Independence MO
    No one? Oh well...
    On a bright note, the shop that installed my SRT diff apparently nicked the axle seal on the right side and it was leaking when driving only. I took it to the Dealer I bought it from under the 3/36k warranty to get it fixed and they replaced both seals for me on the Diff under warranty even though it was a different than original rear end! Will wonders never cease!
    Now I have to figure out somehow what the hex size is for the drain and fill plugs so I can put the good lube in that I have...
    ____________
    RobAGD's Avatar
    Reston, Va
    14mm Hex
    I used a Big good quality allen key that I cut a nub off and use a 14mm End wrench.
    Works like a charm
    -R
    Fargo59's Avatar
    yep, 14mm hex key. should be able to pick that up at many hardware/tool stores, or if you like shiny expensive tools (or have to for work), buy it from a tool truck like me.
    Nov 2008
    Independence MO
    Thanks guys. I may already have one of those mated to a socket that I can use. I will have to check.
    I appreciate your input!
    ____________
