Results 1 to 11 of 11
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    SRT Differential question
    Do the R/T half shafts fit the SRT Rear Diffs? need to know before I buy the diff?
    Charger4Life's Avatar
    Charger4Life is offline I'd rather be racing.................
    Greenville, South Carolina
    Quote Originally Posted by stitchmonkey View Post
    No they do not. The SRT halfshafts fit the R/T hubs though so your good on the wheel side of the assembly.
    Frank's SPARROW cam, Indy Maxx heads, LMI Fender Pull Intake, Edge High Stall Converter, Full SRT exhaust, 399 rwhp, 407 ft.*lbs.
    5.7 N/A 11 second club Best times to date:
    1/8 mile E.T. 7.42 @ 93.53 mph.
    1/4 mile E.T. 11.696 @ 114.24 mph.
    1.60 60 ft. best
    slideway's Avatar
    slideway is online now Onward, through the fog
    Jun 2007
    Union co. N.J.
    No, r/t diff.=210mm srt diff =215mm. You need the diff, shaft's, hubs. rear drive shaft piece.
    hey what do ya know, I just happen to have a whole setup comming up for sale as soon as I swap my new set in.(waiting on a drive shaft tail)
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by slideway View Post
    He doesn't need the hubs if going from R/T to SRT, just the pumpkin, axles, and drive shaft. We spent a LOT of time at Cam's comparing 5.7 and 6.1 hubs. They're the same with the same part number.
    Feb 2007
    So I'll need a driveshaft too? I thought I got a good deal on the diff now shafts and a driveshaft?will it ever end?
    Motor's Avatar
    Motor is offline pwrparts.com | Eric von Motor
    Chicago, Illinois
    you'll just need the rear portion of the d/s
    RIP - 05 Dodge 'Dirty Whore' Magnum R/T (12/7/11)
    Current - 11 Ford 'Whorus' Taurus Limited - a step back from modding
    slideway's Avatar
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by 1fastsedan View Post
    Ok, Thank's for the info. It's probably good to get hubs to if possible for the stud's should they get messed up along the line, their exp.$
    QuickRT2SRT's Avatar
    QuickRT2SRT is offline Old School drivin' New School HEMI
    Nov 2008
    Independence MO
    I recently swapped my RT diff out for the SRT unit to get the 3.06 gear and what has been stated is correct... You only need the SRT halfshafts, the rear of the SRT driveshaft and the pumpkin.
    A note of caution... make sure there are tone rings on the axles going in, or they will have to be carefully removed from the stock axles and installed on the SRT axles... You wiill go in instant limp mode if both are missing... car no go, nada... nix... I found out the hard way and it cost me an extra day while the shop redid the job right...
    Love the new gear tho!!!
    2007 Charger R/T - 5.7L Hemi Registry #1055 w/ username QuickRT - Gone/Traded on SRT8
    07 Torred Charger SRT8 - 6.1L Hemi Registry #1151 Mods:
    Predator Modified 93CAI tune, AirRaid SRT8 CAI, Mopar/Corsa CatBack, AMG Paddle Shifters, 4128 t'stat, BT Catch Can, ChillyMod, More to come...
    PB 1/4 ET 12.708 @ 109.10 1.95 60'
    ____________
    Feb 2007
    Quote Originally Posted by QuickRT View Post
    Thanks for the info, did the new gears mess with your gas mileage much?
    My gas mileage is about the same highway and slightly better city than before the gear swap.
    1.60 60 ft. best
    Feb 2007
    Quote Originally Posted by Charger4Life View Post
    Cool, Thanks.
