if anyone has a 6 speed manual trans, this is a cheap mod that has massive results. nothing worse then cruising past a group of hot (insert gender here) in first gear going slow and going for the shift and have it go into fourth and start lugging because you didnt realize it.five minutes under the car and now your tranny works like it should and goes into the gear you want it to
1970 scat pack decals inside quarter windows
skip shift eliminator
functional hood vents
painted calipers with dodge decals
Hurst shifter
Spectre fender mount cai
bt catch can
bt mopar hood badge
predator tuner
180 thermostat
Shad do yah think the teacher's gonna look like this year!
Give me somethin' to write on!
2005 Magnum RT AWD 344AWHP/358AWTRQ
FRI Sidewinder Cam, Johan Tune, Edelbrock Headers, JBA Hi-Flo Cats, Magnaflow Catback, 180* T-stat, aFe Stg II CAI, 85mm Throttle Body, SLP 25% UDP, Catch Can, Taylor Shortys, Freak351 Trans Box , Eibach Pro Kit Springs & R1's. Interior, Engine & "M" Emblems by Billet Tech, R/T Emblems, Magnum R/T Grille, Black Heads & Tails, Eyelids
