Results 1 to 5 of 5
    OsO's Avatar
    OsO
    OsO is offline If you will slow down i will look faster
    Jun 2008
    Houston TX
    Sealing issue with the dss axels and getrag???
    Just installed 1400hp axles and the driver side seal on the rear is leaking. The seal has no nicks and only has about 10k on it. Has anyone had the same issue after an axle install??
    Waiting for the car to cool down so i can measure the oem shafts and the dss shafts to compare.
    If anyone knows the part number for the seals please post it.
    New toy
    2009 SRT Challenger soon to be Powered by 468ci of go fauck yourself
    Old toy
    4500lbs SRT 300c N/A 440 11.2@ 121
    F&%@ you were from Texas!!
    1FST4DR's Avatar
    1FST4DR is online now I just dont get it...
    Ft Laud.....
    Make sure the vent isnt clogged as well..
    Stricnine is offline LX Newbie
    Aug 2009
    I had problems with the driver's side leaking when the axle slid out just enough to make the seal useless.
    The Getrag axle seal is p/n: 68049799AA
    Make sure the axle is in all the way. I ended up swapping the stock "clips" in place of the DSS clips to keep the axle from sliding out of the differential. I haven't had them slide out since.
    2009 Challenger R/T 6 speed.
    Best 1/8: 1.671 60', 7.63 @ 89.75 DA 1824 ft
    Best 1/4: 1.810 60', 11.959 @ 115.92. DA 516 ft.
    1979 Dodge Li'l Red Truck
    OsO's Avatar
    OsO
    Jun 2008
    Houston TX
    Quote Originally Posted by 1FST4DR View Post
    I will check since i am there , thanks.
    Quote Originally Posted by Stricnine View Post
    Getrag axle seal p/n: 68049799AA
    Axel is seated all the way in but can be pulled out with very little effort, will look into swapping clips when new seals arrive, thanks.
    Aug 2009
    Quote Originally Posted by OsO View Post
    That's the exact problem I had with mine. I could pull them out by hand.
