Results 1 to 8 of 8
    Big Boy's Avatar
    Big Boy is online now 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    Question for those with the Richmond Gears
    Are they noisy?
    After talking to my drivetrain professional today, he told me that Richmond quality control has slipped over the years and most of their gear sets are noisy around 65-75 mph.
    Also, what ratio are you running and why?
    Johnparts's Avatar
    Johnparts is offline 5.7 Hemi Plymouth Scamp
    Dec 2007
    Naperville Il
    Silent as stock in the ones I've set up. It's really a matter of who installs the gear.
    Posted via LXFMobile
    Super T's Avatar
    Aurora, IL
    John - were mine Richmond??? The only noise in the 3.55's I had was a little bit of whine when I was coasting down hard (manual downshift to stop).
    Big Boy's Avatar
    Feb 2006
    Columbia Ridge, OR
    Quote Originally Posted by Johnparts View Post
    In reading the chargerforums there was a concern about gear noise with the Richmond Gears. So, what you're saying that was because of bad installs?
    Johnparts's Avatar
    Dec 2007
    Naperville Il
    Yes 90% of all gear noise is directly related to improper Backlash settings. The Mercedes rear is tight and much tighter then most are use to. It is really important to make sure your backlash is between .005 and .008 on these rears any looser and you will get a whine on decel.
    wephillips's Avatar
    wephillips is offline I LIKE TO GO FAST!!!!(DFWLX)
    May 2009
    Mineral Wells, TX
    I have multiple friends that work in gear shops and they all say the same thing, DON'T BUY RICHMOND GEARS for DAILY DRIVERS due to the gear noise.
    09 Challenger R/T
    DodgeDude99's Avatar
    DodgeDude99 is offline LX Padiwan
    I have always heard and been told Richmond gears whine as well. everything i research on it point to either the steel or the way they treat the gears. alot of my friends run Richmond in their offroad rigs, but whine isnt a big concern because you get just as much from the mud tires.
    as far as the mercedes rear end being tight, i never did gears in one, but have done alot of dana axles & GM, 0.005-0.008 is about normal, almost all of GM & Dana axles are 0.006-0.010.
    but they are decent gears from my experience.
    Big Boy's Avatar
    Feb 2006
    Columbia Ridge, OR
    Quote Originally Posted by DodgeDude99 View Post
    Can I assume you are talking about the Richmond gears being decent?
