Thanks for any replies in advance. I've got an 08 SRT8 charger, that I put a vortech kit on a couple of thousand miles ago.
This last Friday, I installed some zoomers, drove it around for a couple of days, and then installed a new PI 2800 RPM torque converter on Monday. Did some light driving, no problem at all, car felt great.
Get it back home, and I noticed that the fluid wasn't running very fast through the aftercooler reservoir, so I figured I had a air bubble, took the top on, and cycled the key from off, to on (without starting), a bunch of times. The electric water pump is wired to the fuel pump fuse, so cycling on and off basically runs the pump for a minute.
Next I go to start the car, it starts for a second, and dies. Try a few more times, and it dies every time. I figured I flooded it or something, left it for an hour, at this point it won't even turn over. I pull the battery, try again, nothing. Check it with my predator, no codes, I even go so far as to re-write the canned vortech tune, still won't turnover. Get pissed off and go inside.
Wait a little longer, come back, and the car starts. It runs for a few minutes, then I go to rev it, just to make myself feel better, and it dies.
Now I'm in over my head, I quit, and go to bed.
Tonight I try again, I check the car over, check the tranny for any loose lines, check the fuse in the fuel pressure booster, all good. no workie. I climb over the car again, spot check a few fuses, and the car starts. I don't dare touch the throttle this time, as I'd like to let it charge a bit. After a couple of minutes, car dies, back to the point now where it won't turn over again. I can hear the starter working it's butt off, but no workie.
Any ideas? I could use some. I'm going to check fuses again, I'm at a loss as there are no codes, and I can't see anything wrong.
Thanks.
both of you!
