Results 1 to 8 of 8
Thread: mtcm in 2007
    SILVER ROCKET is offline LX Padiwan
    Aug 2008
    spring hill fl
    mtcm in 2007
    my question is what happens if you put the mptcm in a 2007?will it work?has anyone done it and if so what happened ?tried to find threads but could not find any body that has done it just that it cant be done because of communication speed (can bus).
    heads cam lts high fl cats
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    I believe it works on 05 & 06 only, NCG3 and 07 has NCG4, I think!
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I replaced my 05RT's transmission with an 07 one from a RT Charger. I had the upgrade TCM and the car would not drive with that. Reinstalled the original one and it drives fine. I do miss those firm shifts now!
    Aug 2008
    spring hill fl
    the reason iam asking is because my friend put one in friday and working .harder shifts and holds in gear he said a big diff with the mopar stall conv.has anybody also done this on a 2007???
    Fargo59's Avatar
    really? its not supposed to work. ive called up mopar's techline and asked why. NGC4 in 2007+ processes too fast for the Mopar TCM. are you sure his car is an 07?
    SUPERFYSS is offline LX Newbie
    May 2009
    I checked
    Quote Originally Posted by fargo59 View Post
    Hello forum. I'm the guy who used the mopor tcm on the 300 i checked my payment book it's definately an 07
    May 2009
    i called the direct connection hotline. they told me that as long as i used the predator tuner to alter the rev limiter it would work. i plugged it in without initializing it and set the adaptives the way the instructions told me to. it works great !!! and silver rocket is probably running a 2.7 in that brick he's driving....631 keepin it real
    May 2009
    just kidding he's a friend of mine......believe me it works and makes a huge difference. i'm running stock pcm with a predator tune done by aj who i'm sure is familliar to alot of you guys on the forum... definately the reason the car runs so well.
