Results 1 to 15 of 16
    DVSSRT8's Avatar
    DVSSRT8 is offline World's fastest N/A stock block 6.1!!
    Feb 2007
    Nor Cal
    Mopar TCM problem
    So i do what everyone says to do plug in the tcm change the gear ratio to 3.07 and bam it should be gravy. Well I did exactly that when i turn the key theres a snowflake * were the D is suppose to be and no throttle response the car cannot even be driven. Whats going on has anyone every had this problem?
    N/A 6.1 Heavy Weight Champion 11.11@126
    HHP Stage 2 Always Imitated Never Duplicated
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Make sure you didn't accidently break any of the wires on the TCM connections. That's exactly what happened to me when I broke some wires on my tranny connector.
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    DVSSRT8's Avatar
    Feb 2007
    Nor Cal
    But i put it back in the stock tcm and everything is fine.
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    Quote Originally Posted by DVSSRT8 View Post
    What year is your car?
    I believe the MTCM only works on the 05-06 cars.
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    DVSSRT8's Avatar
    Feb 2007
    Nor Cal
    06
    carchitect's Avatar
    Morton Grove, IL
    I'm assuming you changed the gear ratio via a predator? Why though, SRTs ahave 3.06's from the factory and the PCM is setup for that ratio, so why change it?
    Was the MTCM plugged in at the time you the predator(if you used it)?
    DVSSRT8's Avatar
    Feb 2007
    Nor Cal
    The tcm was originally design fir the 5.7
    carchitect's Avatar
    Morton Grove, IL
    Gotcha... for some reason I thought that they could be used in a 6.1 as well.
    Well as long as the MTCM wasn't plugged in when you flashed your car with the Predator then you could probably sell it if it is not meant to work with SRTs. Otherwise from what I've read it's just a paperweight now.
    tmac06srt8's Avatar
    tmac06srt8 is offline LX Guru
    Mar 2008
    Gresham, OR
    Supposedly it can be used in SRT8's. Wonder if you bricked it with the predator. Maybe someone local can try it on their car to make sure it is just a glitch on your car, and the TCM is not damaged.
    _
    Magnaflow exhaust and HF's|LMI CF intake|4127 Tstat|DiabloSport Trinity|Spartan Max
    SVS Tune 12.875 on 22's
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Even if you bricked it, the worst that would happen is it would act like the stock TCM. This sounds more like just a bad TCM from Mopar.
    MoPOWeR-349's Avatar
    MoPOWeR-349 is offline Whiskey Tango Foxtrot: Buster Buster
    Nor Cal
    Quote Originally Posted by tmac06srt8 View Post
    Not sure why we didn't think of that when I was there--we should have tried it in my car. If you're planning to make it to the track this coming weds let me know, we can try it then if you like.
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Since I have changed rear ends I have not had my MTCM hooked up, just changed the gear ratio in the stock TCM to 3.07.
    Has anyone else run into a problem with this, do you just modify the tune and change the gear ratio or do it in QA
    Video
    USCG Charger's Avatar
    USCG Charger is offline Inertia 383 Stroked
    Jan 2007
    A few thing to add here..
    1) I recently erased my MTCM and left it in there and my car would go into limp mode while driving around for on reason.. and the car just acted up overall.. WhenI replaced the MTCM with a new one it fixed everything the car was doing.
    2) if u have a gear change then all u need to do is plug the MTCM in and change the gears under the quick adjust menu.
    InferAl's Avatar
    Nov 2006
    NE Ohio
    Quote Originally Posted by USCG Charger View Post
    So every time you modify something in your tune A/F or timing..... you redo the gear ratio in QA ?
    Video
    Jan 2007
