Results 1 to 5 of 5
    Blackwagon is offline LX Newbie
    Sep 2008
    Vancouver BC
    leaking transmission fluid??
    I've noticed this morning some transmission oil on the garage floor where my 05 RT Magnum usually sits. I have only 12000 miles on it and the mod are Borla exhaust, CAI and predator. Any advice would be much appreciated.
    Toddo's Avatar
    Toddo is offline Ask Questions while Re-Loading
    Apr 2008
    Peterborough, Ontario
    i had a couple some drips when i first got mine, took it in an they said it was a small leak by a sensor on the tranny, took a few mins for them to fix/replace, i think its common? im sure more ppl will chime in soon with better ideas/details
    06HEMIR/T's Avatar
    06HEMIR/T is offline Wrench
    Nov 2008
    Elizaville N.Y
    Sounds like the infamous connector leak. There is a spot on the trans where the electrical connection is that leaks. There are 2 o-rings that are prone to failure. Should be on the passenger side near the trans dip stick tube.
    Embroidered Leather Console Cover BY JINA, Dynomax Mufflers, Reso Delete, Superchips, Bt Front & Rear Badges, True Cold Air Intake TruFiber 3" Cowl Hood, FlashTech Halo's ( The Best Halo's Around)
    Sep 2008
    Vancouver BC
    Yup, that's exactly where I found it. Thanks.
    dpshook's Avatar
    dpshook is offline LX Padiwan
    Feb 2008
    omg yet another thread about this.... can some one just put a sticky up about this! lol
    I eat through end links like candy bars!
