After breaking a shaft at the track I swapped out for the 09 R/T axels with the upgraded hubs. Been running them for less than 2 weeks with no issues until this morning - I discovered a silver dollar size puddle coming from the left spline side, that had dripped off of the exhaust. Doesn't seem to be leaking at all this morning after a brief drive. I didn't replace the axel seals or flat washer, but they looked fine. I did do several burnouts yesterday...:(
I think the over flow is on that side, maybe the burn outs heated the fluid and it expanded out of the vent.
Check for where the vent is and see if that area is damp.
-R
I just checked, the damp area is isolated to the bottom of the dust seal 1/2" on each side of the drip. Must be the axel seal. Thanks for the suggestion.
What looks like the seal could still be the vent. I thought the seal was leaking on mine too and it ended up being throught the vent.
2006 300C SRT8
Bests: E/T - 11.428, MPH - 122.59, 60' - 1.6216
Best E/T Run: 11.428 @ 121.91 w/ 1.751 - 60'
RDP Heads, RDP Cam, RDP CMR Tune, RDP CAI, Stock bottom-end, 75 Shot Nitrous
It's coming from the bottom of the seal, & it's not coming from the top of the differential. Dripping down onto the corsa exhaust, but it's a pretty slow leak. The next step will be to replace the seal & flat washer I guess.
Vent is on the passenger side. The getrag vent may be on the driver but I know the others are on the passenger.
I had the same thing happen. You probably nicked the seal either getting the old one out or new one in.
I have a brand new seal I could sell you dirt cheap like shipping cost and ship it monday. I have the getrag now so I don't need it.
Frank's SPARROW cam, Indy Maxx heads, LMI Fender Pull Intake, Edge High Stall Converter, Full SRT exhaust, 399 rwhp, 407 ft.*lbs.
5.7 N/A 11 second club Best times to date:
1/8 mile E.T. 7.42 @ 93.53 mph.
1/4 mile E.T. 11.696 @ 114.24 mph.
1.60 60 ft. best
2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, LMI Intake, MTCM, Techo Strut Brace, lowered, Tuned by Diablotoona SOLD--2005 Mineral Gray AWD Hemi Registry # 1154
I have a Getrag 3.73 that is a good deal right now. Only 5 miles on it. But then you may kick my butt at the drags. Also make sure the axle is in all the way, maybe the clip didn't lock in.
Having as much fun possible making power, with good friends
11.521@ 117.83 NA /11.007 @ 123.5 MPH N2O Stock cam and heads, diablo with DINGS CMR tune, 90mm TB, 373 gears, BB 4400 TC, (costom exhaust, CAI, ported intake manifold By DINGS), larger injectors for E-85, slicks, self made N20 kit and roll bar.
