Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    1fastsedan's Avatar
    almost Mexico, CA
    How to install a new differential/axles
    I had a few people ask me for pics of doing my diff swap yesterday. We took a few along the way, so here is one stop shopping for putting an 09 Getrag LSD diff, 09 axles/hubs, and an 09 drive shaft into an 05-08 SRT. Install text from Erik (Hemi31’s) excellent axle swap thread.
    Parts:
    Qty. Part number
    2 Hubs 4779572AA
    1 Left axle 4578733AB
    1 Right axle 4578732AC
    1 226mm LSD Diff with 3.06 gear 5038293AD
    1 09 driveshaft (Charger/300/Magnum length) 5038864AB
    You'll also need a new pinion bolt. M10 1.50 pitch 150mm long.
    http://www.mcmaster.com/#91290a558/=1ne1hz
    If you’re going to use an 09 driveshaft, you’ll also need 3 M12 1.25 pitch nuts (I used nylocks). The new driveshaft uses different bolts to attach to the diff. You may also be able take out the new bolts and just re-use the T60 bolts, but we didn't try.
    The new diff uses 75-90 gear oil, NOT the 75-140 used on the 215mm SRT diff. The Getrag diff comes filled, but you’ll need a liter to top it off.
    Tools:
    Strong 3/8" Ratchet and breaker bar
    21mm short socket
    18mm short socket
    15 mm deep socket
    13mm deep socket
    1 1/4" socket and 1/2" ratchet for axle nut
    18" 3/8 drive extension
    3/8 drive swivel
    E12 Torx socket, 3/8” drive
    5/16" allen key or socket
    18mm box wrench
    T-60 Torx socket
    large flat blade screwdriver or small prybar.
    small flat blade screwdriver
    small hammer
    small piece of soft pine.
    4 Jack stands and a good Jack......2-3 ton is preferable.
    Start by getting the car in the air. I like to put the first two jack stands in the rear pockets on the rocker panels. Get it up as high as possible.
    Next the exhaust needs to come off(in one piece).Loosen the forward clamps, remove the center brace, use a little wd-40 on the center rubbers and pry them off the exhaust hooks, then remove the four 13mm bolts holding the rear hangers while someone holds the tips up. If you’re by your self you can let them down.....just put some cardboard under the tips and polished parts.
    Now wiggle the exhaust back and forth till it slides off the cat pipes and pull it out from under the car and out of the way.
    (my exhaust is all welded, so we took the mid pipes off too)
    Ok.......get the rear wheels off. Set the E-Brake. Using the 1 1/4 socket remove the axle nuts.
    Now jack up the control arms slowly so they are horizontal to the ground and stick the jack stands under them.....this needs to be done to make room for the axles to swing.
    Put the transmission in neutral so you can turn the driveshaft. Release E-brake.
    So now that your completely committed(or should be)......grab the T-60 Torx and the 18mm box wrench and take out the four driveshaft bolts on the differential side of the yolk(silver ones).....you will need to pry the driveshaft back from the pinion. Move the shaft out of the way.
    Place the jack under the differential and bring the pad up so it just makes contact. Using the 5/16 allen socket remove the allen bolt from the front of the differential.
    Now get the 21mm ratchet and the breaker bar. The two remaining bolts are in the cradle right in front of the spare tire well......there is only enough room to barely get the ratchet in. You need to take 3-4 pulls and switch sides......work it back and forth like this walking the differential forward till both bolts are out(this is the biggest PITA both removal and replacement).
    Once the differential is free you want to lower the jack slowly, the differential will want to go forward as it goes down so walk the jack with it. Stop the jack about halfway down. You should now be ready to use the prybar to pop the axle out of the differential. You only need to move it about a half inch with the prybar, pry on the axle flange not the seal flange. Do the drivers side first. Once the axle is sliding freely you need to wiggle the differential around till you can move the axle out far enough to angle completely out of the differential, then slide it out of the hub. Now you can do the passenger side easily.
    Lower the differential to the floor. Pull the axles out of the hubs.
    Replacing the hubs for heavy duty or 09 half shafts:
    Make sure you have the studs pressed into the hubs before installation on car.
    While the axles are out of the car using an 18mm socket remove the caliper and hang out of the way with wire. Remove the rotor. Using the 18" extension,E12 3/8" socket and swivel remove the four bolts holding the hub on from the backside of the knuckle.......remove stock hub
    and replace with heavy duty hub. Reinstall bolts and torque to 50 lbft.
    Reinstall rotor and caliper.(70lbft)
    Slide half shafts into the hubs(Oil or anti-sieze the splines) and install and tighten axle nuts.(157 LbFt)Remember, left side is short.
    Raise the differential to the removal height. Oil the splines and slide the passenger side axle into the differential and seat it. Carefully work the drivers side axle in(watch the seal) and raise the jack till axle is all the way in. Make sure it's seated.
    Raise the differential back into position and carefully get the 21mm bolts started(I use antiseze here).Make sure you don't cross thread these.....if your unsure STOP!!
    Tighten the 21mm bolts(162 lbft) and then replace the allen bolt(48lbft)
    Next reinstall the driveshaft and tighten bolts(43lbft)
    remove the jack stands under the control arms.
    Slide the exhaust back under the car. Hold the front of the system up and put the brace back on......this will help if your alone. I will use a strap and tie the rear of the exhaust up so I can get it back on the cat pips......once in place put the center rubbers back on the pipes, remove strap, then install the 4 rear mounts, and finally retighten the forward clamps.
    Put your wheels back on and let the car down.
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    Very nice.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by metgo View Post
    Very nice.
    Ask and ye shall receive...
    Bud's Avatar
    Bud
    Bud is offline Thread Killer
    San Diego, CA
    Great writeup Adam. Beans to you!!!
    2006 Black Charger SRT8
    AKA RICK: Proud Member of the Eastlake Queertette
    Pedders "Full LX Repair" Bushings / KWv2's / Hotchkis Sways
    DC Front STB / Razors Edge 4-Point Rear STB /
    Mopar CAI
    Magnaflow High Flow Cats / Corsa Catback / Predator
    B&G Custom Tune / AMG Paddle Shifters / TranZformer
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by Bud View Post
    Hemi31 did most of the writing, I just cut, pasted, and added pics. But thanks! I hope that it helps someone along the way.
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    Awesome job. Looks like a fun day of modding.
    WWW.SHOWANDPERFORMANCE.COM
    SoCalLX
    Congratuation Del Worsham
    2011 Top Fuel Champion
    Desertcharger's Avatar
    Desertcharger is online now Three Crosses makes for a lonely LX club
    Mar 2008
    Las Cruces, NM
    Good info- thanks!
    Supercharged R/T with R&T: Mopar LTs and Hi-Flows, Magnaflow Cat Back, MSD Coil packs, picking up more used upgrades by the day and custom CMR Tune= 380 RWHP and 412 RWTQ(oh- and 110,000+ miles )
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Nice work, Well laid out! And nice shop Cam!
    btw- The liter of gear fluid is just for topping off perposes if nessesary correct?
    Also I've come to find that the 226mm getrag is noisey bugger compaired to the stock 215mm unit, Whine's like a big old truck rear!
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by slideway View Post
    Correct. Mine took about 1/2 a liter to top off.
    I had a little gear whine on the way home from Cam's, but then the next morning I went out and ran 10 figure 8's, 10 tight right circles, and 10 left circles. Now she's all broken in and I'm pretty sure that the gear whine is gone.
    budoboy's Avatar
    budoboy is online now LX Newbie
    Feb 2006
    I didn't have any gear whine that I can hear but I have Zoomers ...
    *Winner of New Hemi Challenge Class at Mopars at the Strip (Las Vegas) 2010
    *Winner of 6.1L N/A Class and King of the Hill at Atco Modern Mopar Shootout 2010
    slideway's Avatar
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by 1fastsedan View Post
    Quote Originally Posted by budoboy View Post
    I did do the tight left and right circle's. I'm going to recheck the clearence on my corsa's driver side pipe, I now hear a sound akin to differental morse code! lol, I think it's just barely touching. If it's not that I'll put the interior back in and turn up the stereo!
    wbglider's Avatar
    wbglider is offline Built SRT
    Everett Wa.
    Excellent writeup & pics! Beans!
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    Great write up! this should help when I get ready for mine.
    torRed #1169's Avatar
    torRed #1169 is offline Who has the winning lottery numbers ???
    Nov 2006
    15 minutes from Englishtown
    Isn't this write up from Erics thread ???
    RIP nhDave - Never forgotten, my friend
    ______________________________________
    11.59 N/A and 11.19 on 100 shot.
    392 with Frank Racing heads and cam.
    Dominator Converter.
    Install by HEMI31.(BNFY Performance)
    Tuned by LAFRAD.
    nhdave's Avatar
    nhdave is offline This space for rent.
    New Hampshire
    Quote Originally Posted by torRed #1169 View Post
    He credited accordingly..
    06 Inferno Red Magnum SRT8
    Pretty stuff: Blinker mod, Silverstars, Auto Headlight, ERF Backups, 22Elite console w/Jina's stitching
    Go-fast stuff:
    Arrington 426 w/607 cam and FRI Heads by BFNY Performance, Tuned by HemiTuner, Kooks, Protorque 2800, Airhammer, 180 t-stat, Cool-It, B&B Catback
    11.973@112.45 N/A
    11.42@117 - 1.579 60'
    juiced
