Results 1 to 15 of 16
Like Tree1Likes
Thread: HELP!!! 25,000 mile Transmission slipping/slamming 2nd gear
    Krinkov is offline LX Padiwan
    Apr 2012
    Rockwall, Texas
    *UPDATE*25,000 mile Transmission slipping/slamming 2nd gear***UPDATE in OP...FIXED***
    Just returned home yesterday from a 2500 mile road trip. No issues...car was running perfect. This morning my wife tells me she took the car to visit a friend and on the way she floored it off a light. The car shifted like it should during the hard take-off and all the rest of the way to her friends house. When she left her friends house the car immediately began having problems on the 1-2 shift. My wife brought the car directly to me to look at.
    If I take off slowly, say 10% throttle the car goes through first gear then during the gear change if revs up slightly and abruptly goes into secong gear. If I give it say 50% throttle the car revs WAY up during the gear change then SLAMS into second.
    I tried resetting the TCM...nothing. I reset the shift firmness to "Stock"...nothing. I unhooked the battery for five minutes...nothing. I tried to check the trans fluid but with the items I had available it was hard to get a good read as to level. I did notice the fluid looks like it just came from the bottle, and has no strong odor. No obvious leaks, no light/codes. All other shift are normal.
    I find it really hard to believe my trans just "fried" all the sudden. Is it possible a solenoid has failed or something? Maybe a hard part has broken in the trans? I did take it to the strip a week earlier (12.69) but have had zero issues with it until now.
    What do you guys think?
    UPDATE - 6/20/12 - Trans is fixed
    Tech noted among other things...
    "perform driveability test and found no codes. on test drive found trans flare shift on 1-2 and bumps on 2-1...remove trans and completely dissass clean and inspect. found F1 orc has stacked and failed causing flare. Found K1 snap ring has come unseated."
    And here is the list of parts...
    Valve
    Clutch-outer carrier
    Plate-intermediate
    O-ring-Trans oil pump
    Piston-B1 Clutch
    Clutch-front sun gear sprag
    Piston-K1 Clutch
    Seal-Trans
    Seal-Trans
    O-ring
    Fluid-ATF+
    Seal-Output Shaft
    Looks like the mighty NAG1 can be broken even behind a stock motor
    Kind of a bummer...
    2010 Charger Police Package
    12.69 at 106mph - completely stock 5.7 motor - 2093 DA - 4300lbs with driver
    Diablo InTune - 180* Jet Stat - 3.06 open diff - FTI 3200 Converter - Hoosier DR's - K&N drop-in - BT catch can
    sound&security's Avatar
    sound&security is offline NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    well first thing to do is check the trans fluid level and color and smell.. its normal to smell like fish with synthetic trans fluids
    Daphod74 is online now still. accumulating. parts.
    Dec 2011
    Apex, NC
    How long ago was your FTI torque converter installed?
    2005 300C Magnesium Pearlcoat
    BBK 85mm TB, Volant CAI w/lower duct,
    2006 TCM swap
    DS Predator 91 CAI canned tune
    180* t-stat
    Borla cat-back 140112
    SRT struts/springs + Hotchkis sways
    Apr 2012
    Rockwall, Texas
    Approximately 6000 miles ago.
    Installed by me...fluid level verified by dealer.
    Dec 2011
    Apex, NC
    If you use autostick, does it also fail to respond to the shift on 1-2?
    Also - is this a stock TCM?
    Apr 2012
    Rockwall, Texas
    Quote Originally Posted by Daphod74 View Post
    Stock TCM.
    Just tried autostick. If the shift is performed under load it does the same thing...rev up/slam. If the shift occurs while maintaining a speed/rpm then it seems to shift normal.
    Dec 2011
    Apex, NC
    I agree with S&S: definitely get the fluid level verified by the dealer for starters. Since you're not seeing dark fluid or noticing a burnt smell, then it seems to rule out burnt clutches and maybe the solenoids/harness should be checked next (before going deeper) - assuming the fluid level is ok. I would think at your mod level, the transmission should hold up however, I have broken a sprag in a TH400 transmission in a stock car because of a plugged valve body caused by a flush and felt similar slippage - although mine was in 1st gear and worse from a dead stop.
    Rupert's Avatar
    Rupert is online now big bump stick
    Feb 2009
    Bowie, MD
    I had a similar issue, only it came on all of a sudden, and it was my TC clutches had came apart and went...everywhere. You havent had any leaks? so if the fluid level is good I'd suggest you drop the pan and look at whats in it, get a new filter to install before you drive the car any further. Tear the old filter apart and see if its clogged on the inside. As far as I know FTI TCs aren't prone to failure, but IF theres a problem with the TC or, say the valve body, catching it now could save you the 4k it cost me to rebuild my NAG-1. I hope its nothing serious and you figure it out soon.
    08 R/T LMI TRUE CAI, eagle intake, 6.1 injectors. Modern Muscle Performance Group 85mm Ported TB, CAM, and ported eagle heads. SLP underdrive pulley. 6.1 timing set,and lifters, PSI springs custom pushrods, cometic head gaskets, 11:1 comp. American Racing 1 3/4" long tube headers , highflow cats. SLP SRT8 3" catback with Magnaflow 3" mufflers, 4" tips., catch can 170 stat. Builder Bill rebuilt tranny, stage 2 valve body, 3500 stall TC, AFI flexplate. Getrag 3.73 MTCM. BC Coilovers. Pistol grip shifter. Tuning Johan.
    NEW04/6/13: 11.847 @ 118 mph .
    Apr 2012
    Rockwall, Texas
    Dealer just checked the fluid...level is spot on:-(
    Rupert's Avatar
    Feb 2009
    Bowie, MD
    so fluid level is good....Q. Does it ONLy do this in the 1-2 shift? how about other gears and the 3-2 downshift. I fit only does this onthe 1-2 upshift the maybe its isolated to the selinoid.....or some other part of that control portion. when u autostick under light load it shifts normal so Im guessing its not shifting correctly under part throttle let alone WOT.
    Apr 2012
    Rockwall, Texas
    All other up shifts & all down shifts seem normal. If I release the throttle to during the 1-2 up shift it doesn't do it either.
    It's as if whatever clutch/band is responsible for loading the motor during the gear change, just isn't working. The motor just "free-revs" then slams into second like a neutral slam. The more throttle, the worse.
    Given the fact this happened all the sudden I gotta think either it's electrical, or a part has simply snapped inside the trans.
    Trouble is I don't know how to test it, and if I take it to the dealer I have to pull the converter, differential, and programmer off or I'm certain they will fight my warranty claim.
    What a bummer.
    fnkychkn's Avatar
    fnkychkn is online now genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    Quote Originally Posted by Krinkov View Post
    What a bummer.
    ya think?
    Apr 2012
    Rockwall, Texas
    After a re-read that did come off sounding kind of dumb. I was really just trying to explain the pickle I'm in...hoping someone else might have a suggestion on how to confirm what exactly is going on in my trans (other than simply dropping it off at the dealer).
    Still, thanks for the productive comment!!! I now understand how you pushed your post count over the 20K mark :-)
    fnkychkn's Avatar
    as i read all posts in this thread, i had started to assemble a plan of attack for you but when i read that post, i just gave up.
    why are you posting your plans to commit fraud on a public forum? smarten up, bud!
    Apr 2012
    Rockwall, Texas
    Ok then. Thanks.
