So I'm finally going to bet around to installing my 09 Getrag diff in a couple of weeks. I was wondering what you guys are doing for break-in and what gear oil are you using. I talked to my local gear/axle shop and the owner said to run dino oil in a high performance car. He said that the synthetic can't handle the pressure like a dino oil.
Below are 3 break-in procedures that I found on-line. Any thoughts? Which one does Richmond recommend with their gears?
1. Upon differential installation, and fluid top off, proceed to drive vehicle to a controlled
area where several circles/figure eights can be performed. Drive vehicle (at idle speed) in
20 figure eights, full lock to full lock. Then drive (at idle speed) in 20 full lock circles
left, 20 full lock circles right.
All Diffsonline differentials (excluding Kaaz LSDs) require a 1200 mile break in period.
Do not exceed speeds of 85mph as bearings may overheat. Drive vehicle moderately
without extreme load differences such as shocking (hard shifting with swift clutch use).
After 1200 miles, change oil in differential with recommended fluids.
2. Use only high quality name brand gear oil and fill the differential until the oil spills out the plug hole. Positraction carriers require anti-friction additive.
All new gear sets require a break-in period to prevent damage from overheating. After driving the first 15 or 20 miles you must let the differential cool for 30-40 minutes before proceeding. Drive 500 easy miles before towing. Tow for very short distances (less than 15 miles) and let the differential cool before continuing during the first 45 towing miles. Change the gear oil after the first 500 miles. This will remove any metal particles or phosphorus coating that has come from the new gear set.
3. After installation, fill the differential with only premium national brand 80w90 or 85w140 GL-5 gear oil. Also add 4-8 ounces of Dane Spicer friction modifier to the oil if your differential contains a limited-slip or posi unit. Alert: Verify that the drain and fill plugs are properly secured.
-Drive your vehicle easy for 30 minutes or approximately 20 miles. Avoid aggressive starts, hard stops and long distances at a steady speed.
-Let the differential cool for 15-20 minutes.
-Repeat steps 2 and 3 for 1st 100 miles.
-It is not recommended to tow or use WOT during the first 500 miles.
-When towing for the first time, drive easy for 20 miles let the differential cool for 15-20 minutes.
It is recommended to change the differential fluid at 500 miles. Use the lubricant specified in step 1. Subsequent oil changes should be performed every 20,000-30,000 miles.
Many differentials have been damaged by overheating, overloading, inadequate or improper lubrication. The above procedures may be a minor inconvenience, but if followed, your differential should prove to be one of the most dependable devices in your vehicles.
I'll keep my money, guns, and freedom, you can keep the change.
