Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    Feeler::: Deep sump tranny pan for nag 1
    Well with all the talk on how heat is really bad for our transmission,we 'BT'decided to
    take a crack at designing one that is effective as well as affordable.I have all the parts
    needed on the way to me as I type this.
    What Im wondering is should we do both more capacity or maybe just add some cooling fins?My thinking is both.So as usual when Im brain storming on new products I like to
    include the good people of LX Forums.So post up as Im always open to discussion.At this time I have no clue what the cost will be so please dont ask.I will update this thread within the next week or two with a approximate price.
    Thoughts? Ideas?
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    I like the idea. with a drain plug that isn't "straight down" too.
    The trick will be figuring out the proper fill level with the extra fluid.
    As it is there is a prescribed fill level for various temps... and that would change with a different volume of fluid in the system.......
    thats the ONLY thing that I could see as a problem... but I'd be interested in seeing how it works out
    Super T's Avatar
    Aurora, IL
    I certainly think fins wouldn't hurt, but fins will inevitably jack the manufacturing cost way up... Do we know, what is the oil temp and whetted surface area inside the stock pan?
    Fargo59's Avatar
    Pale Rider's Avatar
    Pale Rider is online now Magnum Come Loudly
    Mar 2006
    Western WA
    Do we know, what is the oil temp...
    Kinda what I was wondering. Since most don't have a gauge.
    Sounds like a cool product, I'd just be concerned about over-cooling. We counter that with engine oil with oil cooler thermostats (some systems).
    As far as the oil level check, I'd think a car sitting in a shop, up to full temp, would give an accurate reading whether it's 20 gallons or stock. Still measures height and temp together.
    2006 Stone White MRT
    Sidewinder Cam, Mopar Long Tube Headers, Magnaflow Cats, Magnaflow Mufflers
    13.422 @ 102.84
    All that and a CHROME instrument bezel! YES!
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by lafrad View Post
    No Trick,Got that figured out already.
    I will also be adding a drain plug.And an extra bung for a Transmission temp guage.
    I think putting a guage in the pan wouldnt be the most accurate but i think if the tran
    was to over heat you would know it..
    1FST4DR's Avatar
    Ft Laud.....
    Not as much as you would think Todd..
    1fastsedan's Avatar
    almost Mexico, CA
    I'm interested Scott. I say increased volume and fins. Can't hurt right?
    Hillbilly's Avatar
    Hillbilly is offline Caution.....often sideways.........
    Sep 2007
    That's a keeper....more fluid and more cooling but I personally wouldn't go with fins. The route I would take would definately affect the production costs but it is what it is.
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by Hillbilly View Post
    So what were you thinking??
    Flanman's Avatar
    Flanman is online now I'ze done been Stu'd
    Dec 2005
    Northern Illinois
    Maybe he's thinking of tubes going thru the pan (front to back). Fins would be great. Also remember to check clearance on lowered cars for a deeper sump if that is the route you guys are going. It is tight under there for us lowered guys.
    '05 Magnum R/T-Inertia 407" stroker
    '70 GTX 440-6 (Needs resto)
    '66 Belvedere (Project car)
    '10 Ram 1500 Laramie Crew Cab 4x4
    Quote Originally Posted by Cam View Post
    I just happen think different then most sometimes.
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by Flanman View Post
    True, but there is no way it should hang lower then your exhaust system.Im
    not worried..
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    My only comment, is I would want all the above, fins, 1-2 qaurt exstra, drain plug/tem,
    I would not care if we got ride of the factory retaining bolt set up, but I love to the factory gasket.
    Also FYI, Im not 100% sure about the filter set up, when I removed my VB the filter is lightly sitting in the VB, and looks like it "sits on the bottom of the pan" if the fluid starts sloshing around it could possably knock the filter out of the VB and the VB would not get any fluid,????????
    Just a possable heads up.
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
    HemiPowered5700's Avatar
    HemiPowered5700 is offline Raging Inferno
    Mar 2008
    Chi-Town
    Oh I'm down with this...anyone with a modified LX should do this!
    Let me know where to sign (assuming of course it isn't going to cost billions of dollars) haha
    Posted via LXFMobile
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by 1362#Sublime View Post
    No worries Mike,We will be using the factory gasket.And the filter will have an extension to bring it lower in the pan..
