Results 1 to 15 of 25
    randkcustoms is offline LSx Eater
    Nov 2008
    Exclamation Droping the Diff and need some help ASAP
    Hey guys, im trying to drop the diff for the half shaft install and the hex bolt in front wont come out, its just spinning and i put my hand up there and it fills like a nut or somthing thats spinning with the threads. any hints on geting this out??? Thanks
    1fastsedan's Avatar
    1fastsedan is online now Warranties are for sissies.
    almost Mexico, CA
    You need to put some weight on the nut. Let the diff down until it hangs on the bolt then loosen it.
    Nov 2008
    I got it. Thanks. Next question, the little rubber isalater that fits on the Hub end of the shaft the passenger side fell off when it broke its gone. and the drivers side, is warn out. do i need them? or can i install with out? the new shafts dident have any
    1fastsedan's Avatar
    almost Mexico, CA
    Not sure what part you're talking about. Pics would help.
    Nov 2008
    i dont have a cam. on the axle shaft, there is a round thin peice that slips over the hub side of the axle and it has a layer of rubber on it. there wasent one on the passenger side
    Trojan's Avatar
    Mar 2006
    So Cal
    toner ring's? If so you need those's, and there not sold seperatly.
    Jim "Meister" Edwards
    RIP "SLICK"
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Oh ****, T's right. Your talking about the toner rings. Welp, you need to remove your old one carefully and install on the new shaft. Hopefully it wasn't damaged when the shaft broke. But you car will work with only one, it'll just throw ABS codes.
    1fastsedan's Avatar
    almost Mexico, CA
    You're putting in the 09 Mopar axles right? If so, both of the new ones should come with the tone ring already in place.
    Nov 2008
    No its not the toner rings. just a sec I will put a picture from the service manual on here.
    Well i cant figgger it out, but it shows what im talking about on page 3-47 of the LX Service Manual. Its the bottem picture with the guys finger holding it, that ring.
    SLEEPER 26 is offline POWER PORTED
    Feb 2007
    virginia beach,virginia
    Isolator washer
    Quote Originally Posted by randkcustoms View Post
    Worst case is a click on shifts to reverse, it's simply a noise problem. Note it won't fit on 1000 HP axles. I have heard nothing since my axle install without them, but make sure you get 157LB of torque with an accurate wrench.
    fnkychkn's Avatar
    greasy cardboard box
    this guy?:
    i've seen a few with the rubber worn away and even some without the washer and none of them had any noise concerns.
    Nov 2008
    Yep its that guy. When I took my old half shafts out, ONLY the drivers side had one. and the passenger side dident. Also with the 09 Shafts it dident fit as louse on it as it did on the stock shaft. Can I get them from the dealer?
    Nov 2008
    So do i NEED them? because they are about a week out.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    you should have them, I am surprised they didn't come with the new axles.
    BFNY PERFORMANCE
    RIP My Friend
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    If Fnky says they aren't absolutely necessary...
    I'd believe him.
    this guy?:
