Results 1 to 7 of 7
    Appleseed's Avatar
    Appleseed is offline is blacked out
    Dec 2007
    Milton, Ontario
    Dealership for flash or ?
    As mentioned in a previous thread, my tranny is lagging and shifting roughly up and down since having my mechanic fix it. (oil leaked out, went into limp mode after sensor seal leaked)
    Dealership said it would be about $150 or so to scan it for software updates and apply them if needed after test driving and diagnostics. My mechanic had borrowed a dip stick from the dealership to check levels, but obviously couldn't flash it or check for updates without the proper computer equipment. They did say they had to reset the hazard light concerning the limp mode, so they have at least that much equipment anyway. I'm just not sure what the difference is between what an average good mechanic has and what a dealership has, if any.
    Is my only option to go to a dealership because of their scanning capabilities? Technically, my mechanic filled according to the dipstick. I just don't know of anything I can do myself if what is wrong is computer related.
    On another note, would a Predator correct all that by putting in it's own tranny tuning anyway? I am aware of what the Pred costs, yes.
    Eibach Proline springs/shocks/sways by HalfFast Performance | RT Road and Track exhaust | Predator tune | AIRAID C.A.I. | black powder coated RT wheels | tinted tails and side markers by Obsidian | 2 layers 5% Llumar tints on all 5 | black grille and trim | black headlight and fog covers | debadged | black exhaust tips | demolded | black wings | Magnum belt moldings | Magnum shifter | black lugs | V-LED tail bulbs | lowered front plate | air silencer removed
    Appleseed's Avatar
    Dec 2007
    Milton, Ontario
    Well, that was either the most convoluted question that confused everyone, or nobody knows the answer.
    fnkychkn's Avatar
    greasy cardboard box
    Appleseed's Avatar
    Dec 2007
    Milton, Ontario
    06 300 Touring with a 5 speed.
    fnkychkn's Avatar
    are all shifts rough or just specific ones?
    Appleseed's Avatar
    Dec 2007
    Milton, Ontario
    They all were. I have just gotten the Predator though and that changes everything. With the resetting of the learning feature, it's started over again. I think the Pred flashes it anyway. Now with the new tune in place, all the shift points are different, and it may have cured the problem. I'm still deciding.
    I also still wonder if it has the exact right amount of tranny fluid in it, which I don't think the Pred can tell me.
    fnkychkn's Avatar
    it does sound like a fluid level issue. you should get it checked.
