Brake Stall vs. Flash Stall:
Flash stall is the maximum your engine's torque can stall a torque converter. In essence flash stall and full stall are nearly identical. If you had a transbrake, you could find full stall by putting your foot to the floor and reading your tach. For argument sake, let's say we're testing a 3500 stall. If you had a transbrake, you would see around 3500 rpms. If your motor was at idle and then you suddenly floored the throttle, you might see slightly more (maybe 100 rpm more) stall for a half second as the momentum of the motor's internals "flashed" the converter a small bit above its true stall rating.
Brake stall, on the other hand is a very subjective thing. For most, it's the highest stall you can achieve before your tires spin. This varies greatly based on many factors: Traction, gearing, brake clamping force, and engine torque. With a 3500, I may only be able to get 2200rpm "brake stall" on the street with street tires...any higher rpm and the motor torque would overwhelm the tires. But if I was at the track with racing slicks on the starting line, I might be able to get 3200 brake stall before the motor torque overwhelmed the tires. See...brake stall is very subjective.
More info here.
http://www.converter.cc/tech_talk/
Thats some pretty good information there......I was worried about losing some top end with a higher stall converter. I was thinking either a 2800 or 3000stall, I really didnt want to go any higher then that to begin with and now that makes me want to consider the 2800 even more.
first time out 11.28 @ 123.94MPH 1.89 60ft +3500DA R.I.P Kenne Bell
Call PI, BB, EDGE, APS, TCI, PTC, ATI and just start gathering opinions and advice to help educate you so that you can form a better idea of what is best for you.
I have had more TC in my car than anyone I know... 5 to be exact... each one a higher stall than the last.... IMO with my car higher stall is better.... b ut of course I have different gears and different cam than most.
Usually if u have an incorrect TC stall in ur car then it will happen b4 u shift differect off the line is where the bog will occur.... my first 2800 stall i was bogging in the first 20 ft of my runs then it would run like hell..... but with these cars the 60' is everything.
2006 Magnum SRT8 "HEMIWAGN"; HalfFast Performance built; OST Dyno tuned; Frank Racing Extreme Heads, Scudd Cam & Ported Intake; Paramount Performance Dominator 4400TC & Valvebody. Best 1/4: 10.898 @ 123.25 MPH, 1.577 60', 3500lbs with driver, DA -595
