Results 1 to 10 of 10
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    Can we get info in one place about trany slipage
    OK, I got my 3.23s installed last night and took my boy for a joy ride,
    Anyways it was very plane to the both of us, that my trans is now where shifting like it should. It seem to take for ever before hitting 3rd gear, and this morring going from 2-3 the trans powered all the way to 6300 then lost power to 6000 then hit 6300 then shifted softly
    The shifting seems to have a hesatashion right before the shifts, and there ok shifts, but not strong to say the least.
    I know there are mods out there than may help. BUT just like in the directions of protorq box, if you dress up a pig, its still a pig. So I would rathere fix the issuess before going even farther.
    Also any one ever notice that some times the trans shifts killer, then others it like riding in a ford tempo?
    FYI, I am an 07 so I would of tried the mopar tcm a long time ago.
    Im also thinking I may have burned the cluches up, as I was using a TB on my car, that after some time, make it feel like it didn't even shift at all. So since its remove, Im happy with the fact I can lighty feel a shift now, but not the hesatashion to shift.
    but I can autoshick the car, and hit it, and there is nothing but even in 2nd. If the cluchs were bad I cant see this happing.
    IS this tune, or trans???
    Thanks Iron Mike
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
    Redfox0099's Avatar
    North Charleston, SC
    Contact Southern Hotrod, Eddie is in New Orleans near you and can answer your needs.
    SouthernHotrod's Avatar
    SouthernHotrod is offline Supporting Vendor
    Feb 2006
    New Orleans
    Quote Originally Posted by 1362#Sublime View Post
    Thanks Iron Mike
    Yep, just give us a call. 888-244-4364.
    Thanks!
    Edwin P. Gregory III
    SOUTHERN HOTROD, LLC
    2230 Richland St.
    Kenner, LA 70062
    SOUTHERNHOTROD.com
    888-BIG-HEMI
    Home of the STRONGEST NAG1 Transmission on the PLANET!
    The SHR NAG1 "VIKING"
    Columbus Ohio
    HOG, going to Toco Hell for lunch, I floored it on a back street, as always, a 1-2 shift good, stoped for the light ahead, and when the light turned green, the car would not move foward at all, just rev up.
    I put in N then D and nothing, I had to restart the car, while doing so I noticed the check motor light was on, according to the diablo, there is no falts found!
    What da hell,
    Frank Racing Inc
    Best Run to Date...
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    Sigh welcome to the world of having a BUNCH of Power and torque at your feet ? With street tires you attempt to punch it and you will most likely go into LIMP MODE. Gone are days you can punch it on the street.
    There have been several threads which we have discussed the point of which these NAG1 will start to feel the wrath of all that power. Your having a 392 stroker N/A puts you mighty close to the edge (525 + RWHP) where modification of the transmission is recommended. Adding a power adder on top will put you over the edge into what will be a matter of time before you need a new transmission.
    If you are experiencing issues ... sounds like you WENT over that edge.
    As mention there are a couple of vendors that can assist with hardware modifications. Southern Hotrod has the valvebody kits as well the upgraded transmissions. Builderbill with Paramount Performance also has transmissions available. Time to pick up that phone ?
    N/A ET 10.44@128
    Joy ride TT Challenger 9.71@143
    7.5L Aluminum Block 460 N/A 635RWHP\650RWTQ By Lewis Performance Machine
    Quote:
    Originally Posted by Jack SickSRT
    Bring what you got, run it and STFU!
    1SRT8-2NV's Avatar
    1SRT8-2NV is offline My fuel mileage sucks!!
    Mississippi
    UH oh sounds like the tranny is not playing nice! I am sure that Eddie will be able to help, I actually talked to him about some options for my car last weekend at the SHR meet and greet.
    Columbus Ohio
    Thanks guys, I guess the 3.23s just made the problem show it head. When they say the trans is good for 500 Hp is that rear wheel or motor???
    I just don't get it, I had a 904 manual shift auto in my 71 duster and I forgot to install the kick down linkage, so the brand new trans burned the disk within 50miles from my school. And even once I connected it, and put some Trans X in the trans it slipped all the time not just at shifts.
    My car feels fine, intill the shifts, I would exspect it to slip all the time.
    Frank Racing Inc
    Best Run to Date...
    BlaKDeviL's Avatar
    BlaKDeviL is offline Bottle Fed
    Jan 2008
    VA
    so did you kill the tranny or was it something else??
    Mods: Nitrous Express, NX Maximizer II, FJO Wideband, Nitrous Outlet TB Plate, AirHammer SS Gen I, Diablo Predator, DMH Cutouts, MT E.T. Streets, Custom Painted Grill, BT Emblems & Catch Can, 5% Tint on all windows and 50% on Windshield
    Columbus Ohio
    Quote Originally Posted by BlaKDeviL View Post
    ITs was something eles, I haven't yet pinpointed completly.
    I lowerd the shifting to 6k and left the RPM up, so now the trans shifts earlyer and not so late, this had coused to happne less often.
    I just insalled a killer Paramount Stage 2 vavle body, and the issue is gone!!! The car is a completly diffrent car, I think I just had to much low tq that the car always felt sloppy down low and realy soft shifts.
    When I took off the trans pan, it looked great! So its not slipping, and the vavle body has woken up the beast!
    Frank Racing Inc
    Best Run to Date...
    Adanac Charger's Avatar
    Adanac Charger is offline It's a family sedan... Hang on kids!
    Brooklin, Ontario, Canada
    Brought over from other thread...
    I was haveing the same issue, thats why I started the othere post below, about getting trans slipage in one place, I thought thats what I was exseracneing, but its just as you discribed.
    I didn't realy noticed the problem intill I had my car retuned, I really think there is some underling tune issue, I wish I could get the Masters At the Big D to look at my tune my self.
    I lowerd my trans shift point to 6k and put my RPM rev at 6300rpm. This has helpped but it still happend every once an a blue moon.
    I just installed my Permount vavle body, and I tell you that I have not had the problem since. Trust me I have tried.
    My thoughts...
    Quote Originally Posted by Adanac Charger View Post
    I did a lot of testing and found that the minimum separation between the 1st gear shift point and the rev limiter needed to be 350 rpms on my car. Other gears don't need much of a buffer as the revs come up a lot slower.
    My thoughts on the valve body... the shifts are simply quicker now and don't need as large a buffer between the two settings.
    2006 Charger R/T with Road & Track .-- .Bright Silver
    PWR 419 / Eagle Heads / Fr-230 Cam / MM Ported Intake / C&L CAI / PI 2800 TC / Paramount Valve Body / ATI Flexplate
    Joelvan Rad / Police Oil Cooler / HalfFast B&M Tranny Cooler / CTP DS Loop / SLP Line Lock / Getrag 3.73 / Brembos / 20" Forged Alcoas... and a bunch of other schtuff .
    In the mail... .PWR Apache heads, PWR Fr-240 cam, ARH headers, SpeedRated FTI 3800 TC, Mopar 6.4 fuel pump
    Awesome install by HalfFast Performance !! . . Awesome tune by JerseyBoy !!
