Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
  1. #31
    cosmo420's Avatar
    cosmo420 is offline LX Newbie
    Mar 2009
    West Palm Beach
    Quote Originally Posted by USCG Charger View Post
    There is always some weak link... I worked everything possible from the rear up to the trwnny.. I expect my tranny output shaft or someting further forward to break next...Bill is doing everything he can to keep us on the track but when we are fooling around with these 4K lbs cars it's a endless task.
    I saw a rag joint torn to shreds in this forum topic was driveshaft detonation, thats the part that is in between the driveshaft and rear center section, that rubber donut thingy, I wonder if one can get one in poly eurathane?
  2. #32
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    Quote Originally Posted by InferAl View Post
    This just happened a week or so ago
    He was only asking about getting the Richmonds 5 days ago.....
    Richmond Gears Stronger than Stock?
    RIP NHDave
  3. #33
    legmaker's Avatar
    legmaker is online now LMI Intakes....CF intakes for LX/LC
    orlando, fl
    Quote Originally Posted by cosmo420 View Post
    funny you mention this part........ from the first day i ever looked under the car, i always wondered how those things do not self destruct before anything else????
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
  4. #34
    1362#Sublime's Avatar
    1362#Sublime is offline Chargers, Its all about the Chargers
    Columbus Ohio
    Thanks Al,
    I have had the Richman 3.23's in the 392 Sublime 2 weeks before I took the NA recourd from UC Charger... 6 mounths or so
    I loved the 3.23's it really help my 60fts and you could feel the differance on the street.
    I just got done installing my 430ci with 5.7 heads and intake, and I was takeing her to the track to get a little base run before I finished installing my Harrop 2300...
    I posted the previous post becouse I wanted to know if anyone eles has broken a set of Richman gears yet. I wanted to talk to richman before I made a post about it, but with the holydays I have not been able to get ahold of anyone...
    I hopeing to talking to them tommor befor posting up pics or anymore detals.
    But I will say I wish there was a buit pro rear end, set up, I would actuly pay some money my self, I soooo sick of towing my sublime home.
    3 rear axles, 2 drive shafts, 1 front donut, 5.7 center cunk..
    Frank Racing Inc
    6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
    490 HP and 455 TQ Before Motor and Blower Baby
    Best Run to Date...
    11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
    Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
  5. #35
    Hemi31's Avatar
    Quote Originally Posted by 1362#Sublime View Post
    Thanks Al,
    you blew the gears in a 6.1 or a 5.7 differential? And was it the actual ring and pinion or did the spiders take them out?
  6. #36
    07SRT8MAGNUM's Avatar
    07SRT8MAGNUM is offline Steel Blue MSRT
    Apr 2009
    Fort Walton Beach, FL
    Quote Originally Posted by legmaker View Post
    great point scott....... something to be said for a 10.xx 4-door car that weighs over 2 tons and can be driven in comfort everyday!!! lol
    I'm with you Scott and Legmaker, I don't need to make a race car.....been there , done that......let's take a 4 door and whoop a Vette's ass....
    6.1L Hemi Registry #1142 07SRT8MAGNUM
  7. #37
    Columbus Ohio
    It was the 6.1 center, DO you think Richman will warenty them out?
    And the center section only had 20,000 miles before the gear swap.
  8. #38
    Hemi31's Avatar
    Unless you can visually document every inch of the installation including gear mesh and ring to pinion lash I seriously doubt it.
  9. #39
    netnathan's Avatar
    netnathan is offline Not the Momma
    Corona, CA
    The problem does not exist just with our cars....
    Watch a few episodes of Pinks. Driveline failures make up about 80% of the "catastrophic failures".
    That is a lot of inline power and torque being immediately directed at split right angles to the tires. I asssume quite a "launch shock" to all components after the tranny. That shock load is transmitted thru the rear end to the drive shaft which probably flexes/twists enough to reduce shock to tranny.
    I assume I would rather twist the drive shaft than crunch the tranny. SO I guess we should make the drive shaft the "fusible link" in the system.
    2006 Charger SRT8
    BES/HHP Stage II Heads/Cam/Intake/BBK 85mm TB, NoESP TranZformer
    Hotchkis sways and BFGoodrich 275/40/20 Sport Comp-2 paws
    Predator + CMR = "Custom Dyno/Street Tuned PCM"
  10. #40
    USCG Charger's Avatar
    USCG Charger is offline LX Guru
    Jan 2007
    That builder bill 8.8 rear is not gonna blow....that 8.8 pinion is huge and not to mention the carrier is hurky as well... I think its safe to say that the 8.8 rear is as solid of a peice as your gonna get as of now...
    1968 Dart Supercharged Gen III Hemi
  11. #41
    Columbus Ohio
    I understand what your saying but let me ask you this little queston... What is richmans guidance in installing these gears? "just replace your stock gears with ours and call it a day" this is what I was told when I bought my gears becouse no one sells shims or crush sleaves for our rears. So if ricmans guidance is not to worry about shimming them then they can not use that as an excuse in why they whent bad..
  12. #42
    JimIsland-SRT8's Avatar
    JimIsland-SRT8 is offline make that a 440 please!!
    Aug 2007
    JAMES ISLAND S.C.
    rotglmao..... you are such a douche!!! hahahahahaha
    actually, just for the record, my last bug went 12.5.......... and that is in the 1/4.....not 1/8th......
    Wow, your bug was faster than your Charger!
    Personal Best: coming soon!!
