Do I NEED to raise the shift points Cam?
Just plugged mine in...
Originally Posted by
Cam
Damn, that dealer got's ya all mixed up dude.
First off, remove the lower kick panel below the steering wheel. The TCM is just left of center, you'll see the matching plugs facing you. Leave the stock unit in place, unplug and hook up your mopar TCm and shove it in the hole.
NOW, you do not need nor do you want to have the dealer flash any damn thing, stay away from them. If you do not own a Diablo Predator, you will need one no matter what.
With the Predator go into the "quick adjust" menu only. You need to do two things. One is to raise your shift points and two, change the final drive ratio to 3.06.
Do not for any reason EVER make any changes to you tune outside of the quick adjust menu with the mopar TCM plugged in.
IT WILL BLOW IT OUT.
Other than that, just go have fun.
