Results 1 to 6 of 6
    Sacmagnum's Avatar
    Sacmagnum is offline Juiced and Loving It
    Mar 2008
    Sacramento
    AWD driver transfer case question
    I posted this in AWD also...
    Ok, so I made some more changes to my car...I added a stall converter and had my car tuned at SVS. I took the car out last night for the first time. First pass I just launched it some what easy and turned a 12.07 @ 110.00. Last pass I loaded up the converter, and lauched it hard. All 4 whees spun longer then they ever had before, the esp light flashed, the front wheels stopped spinning and ther rear went up in smoke for about 10 car lengths. No noises, no fluid on the ground, no indication that the transfer case broke. Went out and did a couple of launches and the front wheels are grabbing again.....anyone heard of the the computer being able to dis-engage the front drive in the transfer case?
    Marcus
    2005 Magnum R/T AWD
    JBA HEADERS|HIGH FLOW CATS|JBA CAT BACK|TAYLOR SHORTIES|180 T/S| AFE STAGE 2 INTAKE|DIABLO| ZEX N20 150 SHOT| Nano System | SVS Tune| RDP Torque Converter | R1 CONCEPT DRILLED ROTORS | STAINLESS STEEL BRAKE LINES | DANKO GRILL AND CHIN SPOILER
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    no, but it looks like its time to update the football if you did a 12.07
    madeulooq's Avatar
    madeulooq is offline LX Guru
    JERSEY/VA
    12.07 ??? D*mmmmnnnnnnnnnn...how much juice?
    oh yeah I don't think ur rears should be spinning that much.lol
    MODS..AFE II, DIABLO PREDATOR,SRT EXHAUST,INERTIA HEADS AND SPARTAN CAM(BOB@SVS TUNED)
    >>>>>>THIS IS SPARTA<<<<<
    LouZ's Avatar
    LouZ is offline LX Guru
    Dec 2004
    NY in the mountains
    Quote Originally Posted by Sacmagnum View Post
    Ok, so I made some more changes to my car...I added a stall converter and had my car tuned at SVS. I took the car out last night for the first time. First pass I just launched it some what easy and turned a 12.07 @ 110.00. Last pass I loaded up the converter, and lauched it hard. All 4 whees spun longer then they ever had before, the esp light flashed, the front wheels stopped spinning and ther rear went up in smoke for about 10 car lengths. Your spinning the front shaft bearings or shaving the gears. No noises, no fluid on the ground, no indication that the transfer case broke. Went out and did a couple of launches and the front wheels are grabbing again.....anyone heard of the the computer being able to dis-engage the front drive in the transfer case?
    No such thing ... pure mechanical.
    Marcus
    Sorry I think your about to blow your Tcase. Been there done that. I'd drain the tcase fluid....bet there are shavings in it. The first way you launched is the way to launch a AWD.
    Lou -05 Magnum RT AWD ---> FRI'd 392
    done's Avatar
    Old Hickory, TN
    He says the ESP light flashed. ESP will exercise some control. I could envision that the front wheels were spinning and then controlled by the ESP enough to let the rears continue to spin. If the front brakes were applied by ESP, the torque would have to transfer to the rear wheels. This is a theory, not a definitive explanation.
    LouZ's Avatar
    Dec 2004
    NY in the mountains
    See AWD thread
