Is there any differences between all the brands of tranny fluid which would make one better than the other?
426 stroker, Arrington Phase 4 heads, ported manifold,Dynatech LT, Zoomers, Bishoff cam,CPR fuel rails,Triple Walbro Fore Fuel system ,Aeromotive A1000 fuel regulator, Procharger F1C, Cold Fusion 150 shot (not tuned yet but mounted and ready to go) upgraded TCM, Paramount TC,Paramount High Torque Capacity NAG1, DSS halfshafts.
Rumor is that Valvoline produces Mopar brand. I used some of the Valvoline ATF recently after a torque converter swap without any problems.
Right now Im using Castrol synthetic ATF4 with zero issues.
In order for any brand of fluid to say ATF+4 it has been tested by Chrysler to meet their standards for the fluid.
So you'll be fine with any ATF+4
Read this post:
Transmission fluid type on RT
12.645@108.18
Okay, sounds good. I was just thinking about it since synthetic oil has Royal Purple who people swear by and wondered if there was a company out there that has done some fancy chemical engineering to produce a better tranny fluid.
We use Mopar ATF+4
Edwin P. Gregory III
SOUTHERN HOTROD, LLC
2230 Richland St.
Kenner, LA 70062
SOUTHERNHOTROD.com
WARVIKING.net
888-BIG-HEMI
Home of the STRONGEST NAG1 Transmission on the PLANET!The SHR NAG1 "VIKING"
