Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    randkcustoms is offline LSx Eater
    Nov 2008
    Question Any wright up for halfshaft install??
    Hey guys, I need to replace my Halfshafts with my new 09 R/T ones. Dose anyone have a wright up. I only found the one on swaping the 6.1 rear into a 5.7 Any help would be great. Thanks guys
    slideway's Avatar
    slideway is offline Onward, through the fog
    Jun 2007
    Union co. N.J.
    Yes! Hemi31(Eric) Did an awesome h.shaft repair thread! Also good for replacement of carrier/axles for up grade. Very detailed and instructive! I made 2 copies for myself
    Eric's write up is in the knowlage base under wheels/suspension.
    Also INFERAL sent in pics of his 226 rear end swap in, lot's of good info there too!
    Sorry I am unable to post links, Can't figure it out with Opera browser yet
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    BFNY PERFORMANCE
    RIP My Friend
    HEMISFEAR's Avatar
    HEMISFEAR is offline Your Friendly Canadian Nemesis
    Jan 2007
    Motor City Area ON. Canada
    We used Erik's write-up and everything went successfully.
    Motor's Avatar
    Motor is offline pwrparts.com | Eric von Motor
    Chicago, Illinois
    I used Erik's WRITE-UP as well...def helped out big time!
    RIP - 05 Dodge 'Dirty Whore' Magnum R/T (12/7/11)
    Current - 11 Ford 'Whorus' Taurus Limited - a step back from modding
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    [quote=randkcustoms;2166117]Hey guys, I need to replace my Halfshafts with my new 09 R/T ones. Dose anyone have a wright up. I only found the on
    Does Erik's thread include replacing the hubs as will be neccessary W/the "09" halfshafts?
    Just a heads up, other than that the proceedure would be the same.
    Hemi31's Avatar
    Quote Originally Posted by PowerWagon896 View Post
    yes it does.....since you have to replace the hubs with aftermarket shafts.But then you would have seen that if you read it.
    BFNY PERFORMANCE
    RIP My Friend
    Nov 2008
    Cool, Thanks guys I will print that off
    Nov 2008
    Ok my questoin is this: Since im doing the 09 shafts, I can skip the part were it says lower the Diff right. There is no need for me to need to mess with that right?
    Hemi31's Avatar
    Lowering the diff is the correct way to swap the axles......so no.You can take all the links off the knuckle if you want but I promise you it will take longer.
    BFNY PERFORMANCE
    RIP My Friend
    Nov 2008
    O wow. Ok.
    Nov 2008
    It seems like a PITA to drop it.
    Nov 2008
    How much time should this take??
    Hemi31's Avatar
    2 hrs
    BFNY PERFORMANCE
    RIP My Friend
    Nov 2008
    O wow. that makes me fill much better. is that 2 hr. first time doing it lol or 6th time lol, Im just hopeing that the passenger side isent jamed in there.
