Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Like Tree1Likes
Thread: Installation of the new FLASHTECH RGB HALO KIT!
  1. #16
    TwinCommander's Avatar
    TwinCommander is offline Mutliple Mopar Owner
    Aug 2008
    Hillsboro, OR
    Quote Originally Posted by D-LASH View Post
    Thanks for the response back, but I was wondering if it was wired from the "key-only" power, do you still have to turn the power on the box every time, or will it come on autoMAGICALLY! The color memory's a cool feature, and was hoping its a "default-on" (meaning I wouldn't have to turn them on every, time-daily driver) Probably seems silly to some, but when I 1st hooked up a similar 4ch remote(default-off) I had to have a special wiring design so I didn't need the remote everyday.(turn the key on go!)
    when i had these on the bench, i flipped the power switch on the power supply and the control box remained on, so yes, you should be able to put it to a switched "key on" 12v source.
    2006 Bright Silver Magnum SRT-8
    Air Hammer CAI - AirAid TB Spacer - Diablotoona Equiped
    NGK Iridium Plugs - Magnaflow 3 inch pipes
    BT Catch Can - LED signal lights
    Pioneer Avic Z110BT Hacked and Bypassed
    Factory HID Conversion - Flashtech LED Halos
  2. #17
    D-LASH's Avatar
    D-LASH is offline LX Guru
    Dec 2009
    NC, from LI,NY
    Cool, thanks. Great write up and they look awesome btw!
    (rep added)
  3. #18
    GotMe-N-R/T's Avatar
    GotMe-N-R/T is offline www.mrdanageorge.acnrep.c om
    Nov 2006
    Medford, Long Island
    Is RTV used to re-seal the lens and the rest of the fixture?
    CURRENT MODS: AFE II Intake-PWR Heads and Cam-SLP Long Tubes-SLP UD Pulley-Borla 125s-Eagle Intake-NGK V Power Plugs-Moder Muscle Throttle Body-Mopower Chin Spoiler -BT Oil Catch Can-Innovate Wideband-Eibach Dampers-Hotchkis Sway Bars and Lowering Springs-SRT 8 Gears, Mopar TCM-Edge Racing Converter-TransZformer Shift Kit-Lows/Fogs HIDs
  4. #19
    Nov 2006
    Is window silicone good as a sealant?
  5. #20
    iceysole12345's Avatar
    iceysole12345 is offline Soon to be riding on air!
    Sep 2010
    West Covina Cali
    Quote Originally Posted by GotMe-N-R/T View Post
    Clean all the old glue and buy 3m window weld in a 5/16 size. It's 25 bucks for three boxes of it.. Didn't even use one box. No condensation and it's been about 2 months with going through humidity, rain, and heat
  6. #21
    Aug 2008
    Hillsboro, OR
    so far im getting random bouts with condesation. i have to replace one bucket because its coming to pieces as we speak. the other one though, not sure why. it was great until recently. im gonna throw a bead of sealent around the edge of the lens, then shoot some more red RTV around where the projectors stick out in the back. the RTV made it easy to open one of the buckets back up to replace a halo though, not sure what the 3M stuff would do.
