Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By hemituner
  • 1 Post By Paywithdeath
  • 1 Post By bklynmag
Thread: SUBFRAME PHAIL Thanks to my Bullet Proof Paramount Driveline
    hemituner is offline 10.14@133 ALL MOTOR
    Aug 2008
    Westbury NY
    Over the last couple of races something just hasen't felt right. I figure after 95k and well over 250 passes on the old girl its probably a wise Idea to replace bushings align, and while I am at it install the new brakes so I can try out the 15's. I noticed when I installed the Aluminum 8.8 that the pinion mounting didn't quite work out compared to others that have installed it. Further inspection revealed the Mounting pad is bent like a saucer....... That was only the beginning
    Well Glad I have a Spare. Looking at the Big Picture I figured it would only happen again so with the help of my chassis builder we made some enhancements
    Reinstalled everything back today just need to align and final prep for testing. There is only 1 drivetrain for my Arrington 449 and Paramount drivetrain delivers OVER AND OVER for me Time for another 200 passes
    A.J.
    Meech likes this.
    06 Dodge Charger Arrington IRON 440 V2.0 with 92mm TB, Paramount Trans and 8.8, DSS Custom Axles, Pro Torque Billet Stator Converter, Arrington CAI, American Racing 3 inch Cat Back, American Racing 2 Inch Headers
    ALL MOTOR 10.14@133.12
    TWO TIME MSHS STROKER CHAMPION 2011 2012
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Nice Job
    Video
    Paywithdeath's Avatar
    Paywithdeath is offline 2010 5.7 NA Champion.
    Dec 2008
    Albany NY
    Why 4300lb cows dont stand on there back feet!!!
    Cam's Avatar
    Cam
    Cam is offline effectiveness is not always pretty
    Oct 2005
    Riverside, Ca
    The pinion mount turned sweet bud, great job!.
    Aug 2008
    Westbury NY
    Quote Originally Posted by Cam View Post
    Thanks Cam, Thanks for your help also with the other stuff
    A.J.
    bklynmag is offline 7.4 RT
    Brooklyn, N.Y.
    Glad you found the problem in the shop and not at the track!
    Meech likes this.
    5.7 Personal Best: Heads, Cam and Spray - 11.46 w 1.59 60'
    6.1 Personal Best: Forged, Novi 1500 and Spray - 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Aluminum 449 - 10.736 ET , 1.589 60', 125.05 MPH
    junior666@TTCreations's Avatar
    junior666@TTCreations is offline Home of the 1191hp Jeep!!
    Dec 2008
    li ny
    Boy those welds look nice!!
    Chris Hull
    (516) 532-6662
    All LX/LC SRT and RT welcome
    concussion's Avatar
    concussion is offline So that's what mid 11s look like....
    Charlotte, NC
    Looks great AJ.
    http://www.cardomain.com/ride/3247903
    The Old: Stock 5.7 Bottom End | Lead Foot | 11.861 @ 112.76 1.63 60'
    The New
    : Forged Arrington 6.1 | MMPG Top End | Paramount Drivetrain | 11.67
    legmaker's Avatar
    legmaker is offline LMI Intakes....CF intakes for LX/LC
    orlando, fl
    wow....... glad you caught that when you did. nice work putting things back together!
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Damn,looking good for sure.. Well done..
    Aug 2008
    Westbury NY
    Quote Originally Posted by legmaker View Post
    Agreed, It really got my attention .
    A.J.
    budoboy's Avatar
    budoboy is offline Lightness is my power adder
    Feb 2006
    Great, something else to worry about.
    Are you replacing the bushings while you are at it with solid ones?
    First all motor LX in the 9's
    SRT8_in_CT's Avatar
    SRT8_in_CT is offline If you ain't first you're last
    Jul 2008
    Connecticut
    That ain't goin' anywhere now !!
    Arrington Forged 6.1​..ported 5.7 Eagles..HHP Ported Intake
    227/235 cam..Paramount Trans..Dominator..RPM Roll Bar
    Nitrous Outlet..DSS driveshaft..CTP DSL..'09 Getrag 3.06
    Kooks..Corsa..LMI 4"..ATI 13% UD pulley..Billet Tech..BFNY
    11.65@117.3 w/1.61 60' NA--10.68@126.23 w/1.51 60' N20
    Meech's Avatar
    Meech is online now LX Guru
    Nov 2006
    Nice work AJ !!!!!!!!!!
    Chubby Pro Sways, BCR Coil Overs, Jay's Camber Arms,Speedlogix Bump steer kit/Wretched-Pedders Lower Control Arms BlueTops/CL63 Rear Cooler/JoelVan Rad/PS Cooler/PO Cooler/SRT Max Plus Cam/Forged Push Rods/600HP Half Shafts/Magnaflow Hiflow Cats, Corsa Cat back/ Staggered Satin Vipers wrapped in Vredestein Ultrac Sessantas 275/40/20's (front) & 315/35/20 (rear). HHP Installed Wavetrac/NASCAR Cooling Ducts to ET1970 3" Brake Plates/TI (Track) Backing Plates/ AERO Hood/Naturally Aspirated Force Flow Legmaker CF-F-III STU-HHP Modified HemiTuner DynoTune:
    Diablo 93 Octane 433 RWHP/425 RWTQ
    BB2010SRT8's Avatar
    BB2010SRT8 is offline 2009 CTS-V/2011 Escalade ESV
    Nov 2010
    Mississippi/North Carolina
    Looks good AJ.
    I assure you the habit of modding only gets worse! I know how people on drugs feel. I'm afraid I will start pawning sh*t if I don't get control of myself!
    GONE
    6.1 HEMI, RPM blower cam, 80 lb. injectors, Dual Walbro 255 fuel pumps, D-1SC ProCharger @ 14 psi, Kooks LT's w/High Flow Cats, MagnaFlow exhaust, Paramount Performance High Torque NAG1, Paramount Performance Dominator Torque Converter, DSS driveshaft, DSS 1000 hp axles Suspension-Fully adjustable Pedders, with sway bars and bushings.
    Replacement: 2009 CTS-V 628 rwhp 610 Torque / 750 rwhp 775 Torque with wet 100 shot
