Results 1 to 5 of 5
    Hazman's Avatar
    Hazman is offline Playing with crayons
    Covina Ca.
    Hazman's How to Cut Out Lesson
    I'm using Photoshop CS3(Windows Version) for this lesson
    Open up your photo
    I use these settings
    More Feathering will give a softer edges
    Larger Width will give you a larger tool
    Contrast will look at the differences in dark and light areas that you are cutting out
    Frequency put down more or less anchors
    After the first pass of the Magnetic lasso you need to change tool to the Lasso
    With this tool you can chip away the area you missed
    Be sure to hold down the key for cutting /adding
    After you have a good section
    From the Edit pull down menu Copy and then Paste into a new layer
    Will need to get a small eraser and clean up your edges
    That's it
    Easy
    B00MER's Avatar
    B00MER is offline LX Newbie
    Feb 2008
    Nice thanks for sharing, just wanted to add, I prefer the pen tool over the magnetic wand and the polygon or lasso tool... for the beginner its defiantly nice to use the magnetic wand but if your wanting nice clean cutouts, I'd recommend learning how to use the pen tool to make a selection.
    Some other tutorial i found that is good for learning to use the selection tool to add to your already nice walk-through.
    http://www.tutorial9.net/photoshop/the-selection-tools/
    "Betsy, my little mule"
    05 Pearl Black R/T HEMI / Borla 125 Cat back / Aria Intake / Port&Polish TB / Custom tune by ExaTorq / L5 Kicker 12" Sub Solobaric / 22" Charger SRT8 machine liped Rims / Shaved SRT8 Flat black Fascia / Skull shifter
    Hazman's Avatar
    Covina Ca.
    Quote Originally Posted by B00MER View Post
    You need to give us lesson on using the pen tool for making a selections
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    Thanks Hazman. I need all of the help I can get!
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    CrazyManInCincy's Avatar
    CrazyManInCincy is offline LX Padiwan
    Cincinnati,Ohio
    Thanks I was always using the magic wand tool.
