Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Like Tree13Likes
Thread: The new API 1500 Competition Fuel System spy shots...
    Arrington Engines's Avatar
    Arrington Engines is offline Nascar Proven Power for the Streets
    Aug 2008
    Martinsville, Virginia
    Here is a few shots of the assembled unit, ready to be wired and fitted with pumps. Testing should commence by the end of the week, so look for some updates around that time. The rumored price for the unit by itself with pumps is $750.00 (the pumps wired with external leads, wiring harness not included but will be included in future kits and also avialable seperately).
    JOIN ShopHEMI's Facebook Fanpage
    'We are Arrington Performance, and shopHEMI.com is our aftermarket parts distribution center, ran out of Arrington.'
    866.844.1245
    Order here --> http://www.shophemi.com/
    GIJoe2010's Avatar
    GIJoe2010 is offline The ACR LX is coming, just you wait!!!
    Mar 2008
    Lacey, WA
    too bad it's never seen once it's installed . . . beautiful piece.
    I will never explain myself to a man who rises and sleeps under the blanket of freedom that I provide, then questions the manner in which I provide it.
    GRUNT: Term of affection used to denote that camouflaged, filthy, sweaty, dirt encrusted, foot sore, ripped trouser'd, tired, sleepy, beautiful son of a bitch, who has kept the wolf away from the door for over 200 years.
    BlueBee's Avatar
    BlueBee is offline Nitrous addict
    Portland Oregon
    What pumps will this be using?
    If only two pumps what is max RWHP it can handle on race fuel/pump gas?
    426 STROKER 11.5CR built by Ding's. INERTIA STROKER CAM, Paramount Trans/TransBrake/TC/FLEX/DS/8.8 Differential with 4.10 gears, rwhp 758/ 731 rwtq
    PB N/A 10.948 @ 124 w/-200DA
    Nitrous PB 10.19 @ 136 MPH
    CJR300C's Avatar
    CJR300C is offline Bagged, Dragged, & Blown!!!
    Feb 2007
    FT Bragg, NC
    What is going to be the projected cost for the wiring harness too? Looking forward to the updates.
    V3rbal's Avatar
    V3rbal is offline LX Padiwan
    Feb 2008
    Martinsville, VA
    Quote Originally Posted by BlueBee View Post
    Uses 2 Walbro 400 lph pumps: Walbro 400 LPH Performance Fuel Pump - shopHEMI.com
    RWHP testing is underway; should be no less then 1200 but could max out at 1500. Stay tuned...
    NASCAR Proven POWER for the STREET
    HemiSam's Avatar
    HemiSam is offline happy to be here...
    Jun 2009
    Houston, TX
    Sexy!
    HemiSam
    "A stick car is like a red head. A bit more work, but it's a happy ending..." ;-)
    Arrington 392 with the twins tuned by A.J. "hemituner". World record modern MOPAR 205.7mph at the Texas Mile...
    EXTREME's Avatar
    EXTREME is offline shopHEMI.com
    Oct 2005
    Virginia
    That is down right badass, definitely a work of art!
    Aug 2008
    UPDATE!
    legmaker's Avatar
    legmaker is offline LMI Intakes....CF intakes for LX/LC
    orlando, fl
    no basket? definately an impressive looking piece. really digging the clean wire harness/plugs. i assume this will be like other set ups with no basket and user will need to keep some fuel in the tank to cool the pumps, unless i am missing something.
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
    HEMITECH's Avatar
    HEMITECH is offline LX Padiwan
    Jun 2011
    Very Nice! Does the siphon from the passenger side still work? Where does the fuel return to?
    2008 SRT8 Challenger,PWR forged 6.1 (9.5cr),Mean street heads,stock cam,Arrington 1.7 roller rockers,Hellion twin turbo kit (17psi),SHR Viking trans,Wavetrac rear diff. Johan E85Tune- 10.0 @ 137
    JoeH is offline Driven For Power
    Sep 2011
    As far as needing the basket to hold fuel for cooling, it is not needed for these pumps. The fuel passing through them is sufficient. (GreatQuestion legmaker)
    The design has its own venturi pump built within the system which will connect to the line from the opposite side of the tank for the current return on the factory venturi pump. We are currently in process ofvalidating our calculations for flow based on our internal dimensions for theventuri pump to make sure that we meet and or exceed the needs for theapplication. The new hat will need its own dedicated -8AN fuel line and thefactory line can be used for the return. This system will require an external regulatorthat can be set to the desired pressures based on the need. (Great QuestionHemitech)
    We expect to be able to support most HP applications upto 1500HP at the flywheel with this system. There will be technical directions with eachunit we ship that will detail out the full installation to help prevent or minimizeany questions or issue with installation. I have spent a lot time on the unitto try and avoid any unexpected issues that might come about. But also like tohear the questions of our consumers to make sure that we try to think of everypossible scenario. Thanks for the questions and I will try to answer any otherquestions ASAP. I am not on very often due to my time is spent mostly on designand manufacturing. Thanks for everyone’s interests.
    Lowwlife likes this.
    BuilderBill's Avatar
    BuilderBill is offline Supporting Vendor
    Feb 2007
    Joe...
    A work of art.
    Looks like an excellent design.
    Bill
    Paywithdeath's Avatar
    Paywithdeath is offline 2010 5.7 NA Champion.
    Dec 2008
    Albany NY
    Looks awesome.
    I assume these can be coated to work with E85?
    High Comp 392.
    Sep 2011
    In regards to the E85 we are going to be making a version just for this application that will be coated. With high Ethanol applications, the consumption will go up and I have another version that I am working on that is being finished up currently on the design side for the larger builds in excess of 1500HP. This unit can also be used in the non Ethanol applications that need above 1500HP support.
    Dec 2008
    Albany NY
    Is the other piggyback type fuel pump set up still going to be sold? I need a fuel pump set up to run with E85 but i wont be making anywhere near a thousand HP
