Go big...55-91mm
Kidding, good luck sounds fun. My buddy just got his car back from titan and its a BAD little bitch. Post pictures.
2007 BB Charger - SOLD
2012 Black Mustang 5.0 6 speed - Current
Update engine is done!!!!Ready for install
Starting over with 9 inch
Looks great! Have fun installing the iems3 and make sure the 2 black plugs that go into the black box are seated all the way lol
Front Mount Turbo Hemi RamiEMS3 Tuned
13.92 @ 98.28mph so far
Oh, and its a 4x4
May I ask why youre using the iEMS?
'05 Magnum RT: 392 Twin TC70 Turbo Build
Well I added the iems to help with some drivability issues I had & help from burning up the enginethat might of worked if I could control boost
The iems uses stock map sensor and allows for part throttle closed loop boost fuel correction I was never quite happy with running 1-2 psi boost lite throttle @ 14.7
I"m not planing on running the turbo this year I'm giving up i think I'm just going to try to get an e mail tune and run my engine as is till winter. I got ripped off by my machine shop on my block so i'm kind of low on cash.I did pick up the 80# injectors and would like to use them so I can unload my 40# A tune should be pretty simple with the srt cam & stock displacement a scale job and a few adjustments should be golden
The CMR software does the same things. Of course, there are only a few amount of tuners that know how to do these things, but theyre out there. I think youre making things too complicated. A turbo setup is complicated enough on these cars.
My simple answer: contact Johan, throw him some cash, and bother him with email tunes/datalogging weekly.
Throw Johan some cash? Does he have a dyno?
I wouldn't. Get a respectable mechanic who has a dyno who can modify your car using CMR.
my 2 cents...
Why? every car is different you know!!
North Coast Turbo Systems LLC
Home of the fastest 5.7 Cherokee, 13.39@104.62 MPH
All stock internals 5.7 Hemi with a bolt on turbo, Tuned via the iEMS3
Sharadon Performance Valve Body
Well update me saying I'll leave it N/a lasted 1 week! yesterday I put the turbo all back together. I really haven't got on it much sense it only has 75 miles on it but the afr are very rich 10-10.5. I backed the boost control down for now. I'm still running the 40# injectors all the same settings as the old engine and it actually runs surprisingly well with the inetia heads and 6.1 cam. I did get a deal on some 80# injectors. But haven't changed the fuel line yet. I'll get some pic's tonight.
