Results 1 to 15 of 26
Thread: Single or Twin
    BIGROME26's Avatar
    BIGROME26 is offline Yes..... I am real
    Jun 2007
    Da Westside is the Best side
    Single or Twin
    i have a magnum sxt. a single turbocharger gives 450-800hp with a 3.5 displacement. would i have to get a smaller turbocharger to run a twin turbo set up?
    Ramon's 05 dodge magnum sxt 3.5L
    Mods- Performance: Diablo Predator Tune, AFE Stage II CAI, JBA Shorty Headers,Blastin' Bob's 12db dual exhaust w/ Magnaflow muffler, BT Oil Catch Can. For Looks: 22" Staggard Viper rims, chorme door handles & vents, limo tint, tinted tail lights, walnut wood grain dash/interior, HID lights & fogs. Audio: stock radio, 80G ipod, PowerBass components & tweeters, 1-15" Orion SubWoofer
    Future Mods- debadging & demolding, chin spoiler
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    Twin turbo setups are very difficult to set up correctly. They are also muucho expensive. A single turbo setup will be perfect and I have seen many of them make more power than a twin turbo setup. Theres a reason why Supra's switch out of the twin turbo setups and run a huge single one.
    What kind of turbo are you looking at by the way and what mods do you have done to your 3.5? Why not just buy an SRT for cheap?
    -392 Twin TC70 Turbo Build
    Hillbilly's Avatar
    Hillbilly is offline Caution.....often sideways.........
    Sep 2007
    Can you post a link to a 3.5L making 800hp?
    rickf28's Avatar
    rickf28 is offline I wanna go faster!!
    Nov 2007
    Sumter, SC/ currently Iraq
    Quote Originally Posted by Hillbilly View Post
    That what I was thinking....
    My Name is Rick
    Cars Name is Alice
    SEE SIG ABOVE plus....Lots of BT goodies inside - Lots of custom aluminum inside, Factory REC Nav
    AAC HID fog lights - LED smoked tail lights...with LED bulbs - LED everywhere inside and out
    More to come, Im a broke A$$
    rufwon is offline LX Padiwan
    Dec 2005
    http://forums.corvetteforum.com/show....php?t=1455977
    here is a 800 HP v6 3.5, (actually bored over to 3.6L)
    Although its not a magnum, (Nissan) its still done
    Ron380's Avatar
    Ron380 is offline What do I look like, a comedian?
    Mar 2008
    Dayton, OH
    Quote Originally Posted by rufwon View Post
    Wow! What's that work out to... about a $20,000 engine?! I can't afford that much engine or that many tires!
    2007 TorRed SXT/AWD: Gone, but not forgotten!
    2011 Mustang GT Premium, Kona Blue
    "This is not time for decisions Scooby we have to make up our minds."
    rickf28's Avatar
    Nov 2007
    All I can say is.."Thats insane!"
    My Name is Rick
    Cars Name is Alice
    Hillbilly's Avatar
    Sep 2007
    That's nice and all and mad props to the 350Z owner but that's apples and oranges to me. I'd like to see a 3.5L Mopar do the same thing. Those import motor can reach 1000+ ..... but domestics?
    LX HEMI's Avatar
    LX HEMI is offline RIP Magnum R/T
    Virginia Beach, VA
    You can't use as much PSI on these motors like you can on the imports. Good luck reaching that much HP on a stock 3.5L.
    R.I.P 05 Maggie RT
    Welcome 05 Z71
    CAI, MT's 35's, ProComp 18's, 6" Lift
    06 Harley custom, chopped, dropped and jockied
    AlbertaAMX's Avatar
    AlbertaAMX is offline LX Afficionado
    Feb 2008
    Rocky Mountain House, Alberta Canada
    It's probably doable. Those imports are forged everything, built and blueprinted to the max. If you had enough money to spend you could probably do it. My question is why you would want to spend 30 000 to do that (R&D is expensive) when you could buy an R/T and put in a stroker for a third of the money, then supercharge it (another 7 grand say) to get the rest.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    There is no reason AT ALL to be talking about "import blocks" vs "domestic blocks". There is simply no data or information at all that can justify that argument. Find it and i will eat my words.
    Where do you get that information from? How many turbos have blown up 3.5L mopar blocks?
    How many supercharged mercedes V6's are there running around? pretty similar in design and engineering.
    as with *ANY* turbocharged engine running in the 20psi range, you WILL need to deviate from the factory 10+:1 compression ratio, and use moving parts rated for that much power. Forged crank, forged rods, forged pistons.
    You will need the proper head gaskets and head bolts.
    Beyond that... the boost will make the power, stock heads and cams probably are fine. At those boost levels, you will probably need a metal intake manifold.
    onto single vs dual turbos: talk to a shop that builds turbo setups. not a bunch of forum lackeys. There are pro's and cons to each direction, but a good shop will be able to either setup equally successfully.
    TTMR's Avatar
    TTMR is offline Will wrench for AvGas
    Cincinnati, Ohio
    What he said! Talk to a pro about it, but my guess is that any benifit from twin turbos will be more than offset by the higher price.
    He is just fast everywhere"
    - FlyByU
    Dec 2005
    here is a list of what I ended up doing to my last car. Its not just adding a turbo system and your good to go.
    Short Block - 1mm Overbore, JE Pistons, Eagle Rods, Race Engineering Block Guard (machined), genuine Honda bearrings and gaskets
    Headwork - Port, polish, flowbench, and a competition valve grind
    Turbo - Precision Ball Bearring SCGT3261 with a 56 trim compressor and a 84 trim turbine wheel
    Oil Lines - Goodridge
    Manifold - Drag Gen 3 Cast Iron
    Downpipe - Custom 2.5" mandrel bent
    Dumptube - Mandrel bent
    Heat Wrap
    Intercooler - Spearco bar and plate
    Intake & Piping - Mandrel bent chromed. K&N Filter
    Hose / Fittings / Clamps - High temp
    BOV - Greddy Type S
    Wastegate - Tial 38mm
    MAP Sensor - GM 3 Bar MAP
    Engine Management - Hondata S200 with boost option
    ECU - P28 Chipped ECU and harness
    Plug wires - MSD Magnacore
    Injectors - RC Engineering 550cc
    Fuel Rail - AEM
    Fuel Pump - 255LPH Walbro
    Fuel Pressure Regulator - AEM
    Fuel Filter - AEM
    Fuel Pressure Guage - AEM/VDO
    Motor Mounts - Energy - Urethane
    Clutch - ACT Stage II
    Flywheel - JDM ITR
    New Axel Assembly
    Guages Autometer - Carbon Series - Boost, A/F, Oil, Temp.
    Shifter - B&M short shifter
    Shifter Bushing Kit - Hurst
    Exhaust - Tanabe Hyper Madallion
    Catco High Flow Cat Test Pipe with flex section
    Boost Controller - AR Fabrication
    Power Pulleys - AEM
    Slim Fan - FAL
    I have been around the turbo scene for a long time, and as you can see, know whats involved. I was just pointing out that it can be done. No need to start calling names lafrad, we are all friends here. lol
    but yes talking to a pro is ALWAYS the best first step
    MagnumRT05's Avatar
    Jan 2007
    Westlake, Ohio
    Heat Wrap
    BOV - Greddy Type S
    Fuel Rail - AEM
    Fuel Filter - AEM
    Flywheel - JDM ITR
    New Axel Assembly
    Power Pulleys - AEM
    Slim Fan - FAL
    With the CIS kit, its as easy as "just" adding a turbo kit. Thats the sweet part about it. Now if you want to run more than what Tim recommends, then no doubt youre gonna need some of that stuff. Tim from CIS is THE man when talking about turbos on our cars, so please if anyone is interested in a kit do not hesitate to contact him instead of getting involved with another kit that is not as proven time and time again as the CIS kit.
    stevesrt8 is offline long term car nut
    Feb 2006
    sunny florida
    pays
    as said, it pays to go with the experienced guys.
    That said, IMO and in my personal experience I have noted MUCH less lag and MUCH better throttle response from twin turbo setups. I'm not talking hot 4 bangers, but v-6 and v-8 applications. Does anybody remember the twin turbo SRT8 with the rear mounted units? That thing was crazy, and had instant boost off idle!
    Jeez, hasn't anyone been just dusted by one of those small V-6 Audis?!
    Steve
    06 300C SRT8
