Results 1 to 5 of 5
    Burnaby, BC Canada
    Rear Turbo Setup
    Piecing things together for a simple rear mount turbo setup. Picked up a intercooler, ford giant blue injectors, at tial 44mm wastegate and im gonna get a srt4 map. Still need to get a pump for the oil return also. As far as turbo's go, i have a Garrett T4 AR .84 hot side AR.70 cold. Do you guys think that will work out ok? Im not looking for much here, planning on only running 5-6 psi, just looking to get my car closer to the 11's. Whats a decently priced oil return pump to go with?
    adamwahhab's Avatar
    adamwahhab is offline PPPPSSSSSHHHHHH
    Feb 2008
    FRISCO
    .84 is a little small for the the cubic inches, .96 would have worked a little better throughout the rpm range, but should be a nice build!!! good luck on things...let me know if i can help u out in anyway
    Burnaby, BC Canada
    I figured it was a little small but I got it cheap. I can always swap it out later, might not have enough on the top end but at least i can fab everything up and get it running. Not really much for CMR tuners up here, nobody with much experience with the lx platform. Probably end up doing a email tune just to get up and running.
    8yourM5's Avatar
    8yourM5 is offline Northern CA
    Sep 2008
    good luck with that email tune. I would talk to bob at svs or AJ (hemituner)
    PWR 393, Twin 6262mm Turbos, SHR trans, Fore Fuel system, Wilson Hemi Sheet Metal Manifold
    880 RWHP 775 RWT at 16 psi and 17* of timing
    Tuned by Robert@ Ditos motors
    Walk Softly And Carry Two Big A$$ Turbos!!!
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    As far as oil pump, Weldon has one as well as RB Racing.
    http://www.rbracing-rsr.com/oilsystems.htm
    -392 Twin TC70 Turbo Build
