Results 1 to 12 of 12
    CWHFSR's Avatar
    CWHFSR is offline Cool Vanilla
    Jan 2008
    Gainesville, FL
    Rear mount turbos and the weather
    Howdy!
    Something I've been wondering about with the rear mounted turbos that go under the car. I live in Florida and in the summer the weather forcast is pretty much the same, 90% humidity and a 50/50 chance of rain.
    Well, what will all that rain (big puddles and such) do to the turbos? I know they use a snorkle to put the air filter higher up (though I still don't know where on something like a CIS kit the filter ends up being), but what does a big splash of water do to the turbo?
    SRT8U's Avatar
    SRT8U is online now www.speedlogix.net
    Jun 2006
    South Florida
    On the STS kit the filter is mounted up high via a snorkel so there should be no issues at all.
    Kris | Mopar Specialist | Speedlogix, Inc.
    2006 Charger SRT8 Vortech Supercharged by SpeedLogix
    *** We Price Match - click here to see how it works! ***
    Speedlogix, formerly named BMC Performance ... same people, new name!
    Visit us online at Speedlogix.net or call 888-SPD-LOGX to talk to one of our Mopar experts!
    CWHFSR's Avatar
    Jan 2008
    Gainesville, FL
    Well, I'm more interested in what happens to the turbo itself, not so much the filter because I know that is higher up.
    From what I know (I'm by FAR an expert), the turbo will get pretty darn hot. And from waaaaaaaaaaay back in high school... any metal that gets really hot, then gets hit by water, tends to have problems... so I was wanting to know about the turbo and the turbo housing, how is it effected by going through puddles? In FL you pretty much don't have a choice in the matter a lot of times.
    Tim@NCTSLLC's Avatar
    Tim@NCTSLLC is offline Supporting Vendor
    Nothing, mine has over 31,000 miles on the system with no issues, they are simply not hot enough to experience thermal shock damaging the metal.
    Tim - CIS
    North Coast Turbo Systems LLC
    Home of the fastest 5.7 Cherokee, 13.39@104.62 MPH
    All stock internals 5.7 Hemi with a bolt on turbo, Tuned via the iEMS3
    Sharadon Performance Valve Body
    crhemi's Avatar
    crhemi is offline LX Padiwan
    Dec 2005
    Kauai, Hi
    Quote Originally Posted by Creative Induction Systems View Post
    Tim - CIS
    Have youlogged any track time (to lazy to search)?
    12.95 @ 110 running about 6 - 7 psi, no weight reduction, 20" rims, 3/4 tank of fuel. Spinning till mid way through second.
    Tim - CIS
    Fondy's Avatar
    Fondy is offline YUUUUUUUUUUUUUUUUUUP!
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    Tim - CIS
    I could care less about a 1/4 time if I could do that.
    AWESOME!
    :insert sig here
    Rockinsrt8's Avatar
    Rockinsrt8 is offline Custom LX Accessories
    Charleston,SC
    Ive got the STS twins comming. As long as your not getting on it, something your not liable to do in wet weather anyway, the turbos shouldn't be getting that hot.
    www.qualityrockers.com/PistolGripShifter.htm
    2006 300c SRT8
    388.50 RWHP (naked)
    387.46 RWTQ
    100 shot Zex,Kenne bell boost a pump,Billyboat catbacks, Preditor,
    AirHammer CAI,Dmh E-cutouts,DC strut bar, Hotchkis sways,315s+275s Vredesteins on Giovanna Dalars
    Quote Originally Posted by Fondy View Post
    AWESOME!
    That was on the track, on the street, it is spinning through 3rd.
    That was on 20 x 9 rims with 9.5" wide rubber, not the skinny stock continentals. In that video, it left 165 feet of double black marks.
    Remember, this is an all stock internals 5.7. On the low compression 392 stroker we just finished up, if you punch it at 50 or 60, it WILL go sideways!
    Check out this video link for an example of the stock internals 5.7 under boost.
    Tim - CIS
    CWHFSR's Avatar
    Jan 2008
    Gainesville, FL
    Since I started this thread I guess this can't be a threadjack...
    Is that the stock headers or aftermarket headers for better flow?
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    BTW K&N makes a cover to keep water out called a Dry Charger, it works great, I run one on my Air Hammer. Obviously you can't run it under water, but a little splash, no problem.
    Quote Originally Posted by CWHFSR View Post
    If speaking of my 300C, the engine is all stock, including the stock exhaust manifolds. Elsewhere is was made mention of cats not standing up to forced induction and either breaking them, or melting them. I run factory cats, have over 31,000 miles on them, and never had any issues. My EGT's are kept in check, less than 100 degree increase over maximum stock temps at full boost.
    When set up properly to maintain safe EGT's, there is no concern with the cats. In 2 1/2 years of continuing R&D and close to 100,000 combined road miles, we have never had a failure of a catalytic converter.
    For forced induction alone to raise temps in a cat high enough to cause damage, the combustion chamber temps are going to be so high that the engine will not survive.
    Most cat damage is caused by raw fuel passing through without being burned, and then lighting off in the cat elevating the temps to a dangerous level. That much fuel is also going to cause lubrication issues in the cylinders due to the fuel washing away the thin film of lubricant.
    Tim - CIS
