Results 1 to 9 of 9
    soul infector is offline LX Padiwan
    Jan 2008
    Vortech V3 si max boost
    what is the expected vortech v3 si max boost with 17% OD pulley and 28/30 T vortech pulley on forged 6.1 engine ?
    including all parts necessary as large injectors, fore fuel system... etc
    i searched for many threads but didnt get a clear answer ! can i get 12 -14 psi ?
    Thanks in advance
    9SECBEE's Avatar
    9SECBEE is offline 9 Second Club
    Jun 2009
    Visalia, California
    I ran the V-3 system with a forged 6.4L, 17% OD, 28T pulley, 80 lbs. injectors, Fore dual pump hat, and a smaller pulley on the front "jack shaft" and was only able to achieve 10-11 psi. I made multiple changes (Carbonite on the pulleys, B-Woody manual tensioner, different belts) but could not do any better. You may be able to touch 12 psi on a good day with everything dialed in perfectly, but I doubt it.
    2008 Super Bee #352 - Dyno tuned by Dito's Motors
    cnhman2008's Avatar
    cnhman2008 is online now America F@$k Yeah!!!!!!!!
    Jul 2009
    lancaster pa
    ur gonna need a t-trim to see 14lbs
    Jan 2008
    Quote Originally Posted by BeeSRT8 View Post
    what was your dyno numbers with that setup ? and any 1/4 mile times with that setup ?
    9SECBEE's Avatar
    Jun 2009
    Visalia, California
    Dyno numbers were around 610-630 rwhp (depending on what dyno) and the 1/4 times were 11.3 to 11.5 with 1.6 to 1.7 60 foot times.
    HemiSnake's Avatar
    HemiSnake is offline Problem solved. Problem staying solved.
    Jun 2006
    Lawton, OK
    I have been recently been researching this because I was curious about this with my P1SC. But I think the best way to look at it is not looking at how much boost you are running but by looking at the impeller speed. I know my car is running 13.8 LBS of boost and my impeller is going about 54000 RPM @ 6000 Engine RPM which is about 84% of the max impeller speed for a P1SC (65000). So there is still more room for some boost, but I also read on a website going over 80% of max impeller speed can cause excess wear on your head unit. But based on your impeller speed should tell you how much more room you have to go before you max out.
    I calculated it off this website.
    .Welcome to Force Fed Performance.
    ATI 17% OD Pulley = 7.53"
    Not sure the size of your blower pulley.
    Inertia Motorsports Forged 345ci Block, High Flow Heads, Blower Cam, Procharger P1SC Supercharger, 3.4" Pulley, ATI 17% Overdrive Pulley, Mopar 65lb Injectors, 6.1L Ported/Heat Coated Intake Manifold, 90mm BBK Throttle Body, Mopar Headers, SLP LM II Cat-Back, Speedlogix Fuel Lines Front/Rear Crossover, Aeromotive Fuel Rails & FPR, Billet Fuel Hat with Dual 340 Pumps, Getrag 3.06 LSD with Upgraded Clutch Packs, SHR Transmission, ProTorque 3200 Stall Torque Converter, DSS 1000HP Driveshaft, DSS 1400HP Axles, Billet Tech Catch Can, Hotchkiss Sway Bars, KW Ver. 1 Coilovers.
    610 RWHP/547 RWTQ
    Jan 2008
    Thanks for help
    wink's Avatar
    wink is offline Beast Pilot
    Jan 2011
    Golden, Co
    Most I've got out of my V3/6.1 is 10.3 psi. But with the current setup I'm only seeing 9.6. Both with the 28 tooth cog and 3.125" jackshaft pulley. No OD. But going by the Vortech site I'm pretty much at the limit. Spinning it any faster is gonna heat up the air and lose efficiency. So next will be a YSi.
    wink
    btr's Avatar
    btr
    btr is online now LX Guru
    Aug 2009
    MASS
    what does the 3.1 jackshaft pulley do? I didnt even know what was an option to change
