Results 1 to 15 of 28
Like Tree1Likes
Thread: Thump RRR Racing belt tensioner
    Magnumb_SRT's Avatar
    Magnumb_SRT is offline Dodge Power!
    Oct 2004
    Toronto, Canada
    Howdy folks,
    Purchased a Thump RRR Racing belt tensioner to hopefully alleviate the belt shredding issues I have had last Fall just before I put my Magnum away for the Winter. I have had the Dayco unit (messed up the first one by melting the idler wheel) and am on my second one but it looks like it may be the culprit in shredding the belts on recoil after WOT and full boost (12 lbs on a Maggie). I am thinking the little black spring piece that is extending out of the case on the Dayco is cutting the belt on the recoil....and that the spring can't keep up.
    Btw....I have done some alignment checking with my pulleys, etc using straight edges and a laser and all seem in-line, so I will try this stronger tensioner.
    Anyone tried one of these btw? I was going to put the BWoody manual tensioner on but found this HD spring based one. They used to just make ones for Ford Mustangs using Whipples and Kenne Bell SCs, but now they make a Challenger Hemi model with a standard 70mm idler wheel as shown below.
    Crazy price I know, but the BWoody was $350 and this one is MUCH beefier. Thump RRR Racing Billet Aluminum Pelt Tensioner, Chrysler Challenger, New Jersey, NJ
    Here is a pic of the stock tensioner, beside the Dayco in the middle and the Thump RRR Racing billet model:
    Install was fun today......the thing is so huge that I had to remove the fan assemble It does fit but not a lot of room left around the body of the tensioner. I ran out of time to finish today but will give some feedback of this product shortly and some more install pics.
    Mods: Arrington 426 forged 10.3:1, Magnacharger 12lbs boost, Kooks Stepped LT headers/HF CATs, Corsa Sport cat-back, 90mm Arrington billet throttle body, 4" Glen-made CAI, Eibach sways, Mopar Coil-overs, 22" KMC Nova's, CBD carbon Hood, MyGig, engine bling.
    Performance Team: HalfFast Performance (Chris-"fargo59"), Eastway Dodge (AdamC), BFNY (Erik-"hemi31"), Arrington (Eric, AJ & Don)
    Power: 690 RWHP / 718 TQ
    Track:
    10.87 @129mph w/1.63 60'
    DarthCharger's Avatar
    DarthCharger is offline Supporting Vendor
    Aug 2007
    Cypress, Texas
    Suscribed.
    Sheldon@USWForged.com
    Check Out our Latest Wheel Designs
    Visit Our USW Forged Vendor Section
    713.680.8170 main
    2855 Mangum Road Suite B208
    Houston TX 77092
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
    Torque's Avatar
    Torque is offline Stroke it! Blow it! Spray it!
    Jan 2010
    Jacksonville, NC
    That thing is beastly! But with the price tag its not one I'm going to jump on. Hopefully the dayco holds up with the Vortech. Its nice to have options out there.
    06 MSRT8: HHP Stage 2 Cam, SP Stage 2 Heads, 2800 Protorque Converter, Stage 2 Indy Ported Intake Manifold, Arrington 90mm Throttle body, Kooks Long Tube Headers, Custom Catback, AFE stage 2 CAI, Mopar TCM, BT Catch Can. SOLD
    bozo4's Avatar
    bozo4 is offline LX Padiwan
    Apr 2011
    I have had good luck so far with the dayco on my procharger system with a 3.1 pulley running 11psi.. Different system of course to your maggie..
    Sjohalsrt8's Avatar
    Sjohalsrt8 is offline LX Guru
    Sep 2011
    WORLDWIDE
    Damn eh 350$$$$
    Oct 2004
    Toronto, Canada
    A few more shots and iPhone video:
    bozo4's Avatar
    Apr 2011
    Nice.. What kind of belt is that your running?
    Big Boy's Avatar
    Big Boy is offline 2013 or Bust .....
    Feb 2006
    Columbia Ridge, OR
    For that price that b!tch better have a lifetime warranty.
    As per others, the Dayco works just fine on my KB.
    dgreekman's Avatar
    dgreekman is offline LX Newbie
    just got mine today. Cant wait to get it installed. So tired of breaking belts and tensioners.
    K-1 Technologies 426 Stroker kit, Custom Wiseco inverted dome pistons, port & polished heads and intake, custom grind Comp 426 cam, Polished T-Trim Vortech supercharger, Kooks Longtube headers with flowmaster exhaust, CPR Fuel rails, Walbro 255 fuel pump, MSD Ignition, ARP mains and studs, ATI Balancer, DSS 1000 HP ½ Shafts, LSD, custom Vaca Performance Tune, KW coilovers, Hotkich sway bars, Asanti 3-piece AF-403, polished and anodized engine bay, RK Sport Heritage wing, Alpine and JL audio system, AAC Oracle Demon Eye headlights, tails, and HID Conversion
    www.projectsrt.com
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    Quote Originally Posted by Magnumb_SRT View Post
    Hey Glenn, does your belt still ride on the leading edge of the idler pulleys like in the picture?
    RIP NHDave
    AvantSRT8 is online now Word to your motha ...
    Feb 2008
    Bucks County, PA
    After installing my 8psi Magnuson this weekend, I had the same question as I over looked the install.
    We both seem to be running the same green heavy duty gates belt, so I'm hoping this is the norm.
    Mike
    Hoagie Maker Extroidinair
    MagnaFlow HFC, Corsa C/B, 180 thermo, 8 psi Magnuson, Diablotoona
    Hemi31's Avatar
    I usually shim the idlers so the belt rides the trailing side more than the leading. The belt will walk forward under load.
    Feb 2008
    Bucks County, PA
    I discussed shimming the pulleys about an hour ago in the driveway.
    Standard washers on the stud? 1/8"-1/4" out appropriate?
    Oct 2004
    Toronto, Canada
    No not now. When I was down at Arrington to get the FI cam installed, they added different sized spacers so it sits more near the center (I would say not dead center though....closer to the rear as you mention). I can get an update pic tomorrow.
    hemidup is offline Giddyup!
    Nov 2006
    Minnesota
    Quote Originally Posted by Sjohalsrt8 View Post
    Damn eh 350$$$$
    I took care of my belt issue's for under $10 with the stock tensioner..
    My name is Jerry Williams. Also nick named the Grandaddy of G3 Hemi performance. I love Mopar's, that's my hobby.
