ok guys the instructions that cam with this kit are really disapointing. having trouble with the power steering cooler. there are no pictures of the finished step! it is the last thing i have to do can some 1 help?
'06 INFERNO RED SRT-8 OPTION GROUPS I,II,III
MODS - AIRAID CAI, KOOKS LT's w/HIGHFLOW CATS, JBA FULL 3 INCH CATBACK, PRO TORQUE 2800, SHR CMG-1 CAMSHAFT, PAC RACING VALVE SPRINGS, 12000K HIDs IN PROJECTER HEADLIGHTS, 12000K FOGS, R1 CONCEPTS DRILLED AND SLOTTED ROTORS, CUSTOM GAUGE CLUSTER, CCW 505a WHEELS, NITTO NT05 275/40 ON THE FRONT AND NITTO NT05R 315/35s ON THE REAR, SHR VIKING, D1SC STAGE 2, 3.55 RICHMAND GEARS, SLP LINE LOCK, TUNED BY EPG 3 AT SOUTHERN HOTROD.
What do you need to know? What you're supposed to do with the hoses?
Reason why they are supposed to be bent down is that they hit the sub-bracket if they point forward. The lower hose is just to use a wrench to tighten up so it's out of the way for the bracket, the top one is supposed to be loosened, rotated and held in place by the little metal part with a peg on it. Make sure to check the o-ring on the pipe while you're at it - I forgot and had a pita to fix it.
Thor From Sweden - MSRT '06Procharger P1SC-1 // Ford 80lbLegmakers // AAC // Billet Tech // 3G CustomZ // Diablo
Innovate LC1 // Nitrous Outlet Addict
I'm in the same debacle right as we speak. The ps cooler itself that's on the radiator. Directions don't really say what to do with it.
07 Charger SRT-8
Procharger Stage II D1SC 8 psi
Arrington dual fuel pump
Ford 80lb injectors
1/4 mile: TBD
12.87 @ 108.83 CAI, 180 Tstat, 93 canned tune, street tires
Best I can tell it just goes on the condenser right under the intercooler. Unlike the HO kit which has it mounted vertically. Any other ideas let us know.
i am lost. the screws are smaller then the goles they told you to drill and those 4 inch spacers put the cooler crazy far from annything. disapointed with the instal instructions as a whole.
Agreed. The instructions are lacking big. The rubber discharge off the blower is a tight fit also. I'm just gonna trim that inner fender a little. I'm gonna get some pics up when I'm done with a few helpful things I found.
What did you end up doing with the PS cooler?
