Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    mdany's Avatar
    mdany is offline LX Padiwan
    May 2010
    kuwait
    PCV under the boost issue ...
    when i do wot under the boost ( 9 psi ) i got this issue
    I'm tired from this **** please someone help me
    thanks
    Charger srt8 6.1lL , afe CAI, tune
    BBoyPersia's Avatar
    BBoyPersia is offline eThug cause talkin **** IRL is dangerous
    Aug 2009
    Silver Spring, MD
    Follow my build and racing! www.facebook.com/bboypersiart 9.65 @ 139 - 1.380 60'
    Sponsored By: Drag-On Tuning, HHP Racing
    Quote Originally Posted by Jack SickSRT View Post
    BBOY all I can say is !!
    MOL SRT-8's Avatar
    MOL SRT-8 is offline SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    unless your pvc valve does not have a check ball it not your problem.
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    '05 Magnum RT: 392 Twin TC70 Turbo Build
    MagnumRT05's Avatar
    Jan 2007
    Westlake, Ohio
    And by the way, tossing a breather on each valve cover will help out greatly. You can use a regular breather, or weld some bungs up and run them both to a catch can.
    Edit: Another alternative is what I will be having fabbed up in the future. I will run two valve covers breathers to it as well as my crankcase vent line.
    legmaker's Avatar
    legmaker is online now LMI Intakes....CF intakes for LX/LC
    orlando, fl
    clean out pcv. also might want to look into running a catch can off that fitting.
    FLXC President
    10.19 @ 135 mph PWR forged 6.1 w/novi 1500 s/c @17psi / AfterHours Mopar Perf. installed!!!
    monty1269's Avatar
    monty1269 is offline vajazzle it!....;)
    Aug 2005
    Pompano Beach, Florida
    Just my sillyness... Shouldnt these systems come with a solution for this??
    Hemi Registry 0436 6.1 block - CTP Dual intake - Modern Muscle ported intake manifold - Indy Heads - PWR cam - FTI converter - TTI Longtube(catless) - 3.06 gears - 17 X 8.5 Borbet TS w/ 275/40 Hoosiers - Diablo tuned!! Billet Tech Goodies EVERYWHERE. ALL Parts supplied by LXF vendors: Afterhours Mopar Performance, SpeedRated, PWR, Modern Muscle, Picklefork...and LXForum members. Installed by: Afterhours Mopar Performance
    Sohfast94's Avatar
    Sohfast94 is offline On The Wheel
    Oct 2009
    S. FL
    That's a lot of blowby.
    Especially to make a mess like that.
    mdany's Avatar
    May 2010
    kuwait
    man that catch can look great for this mess
    I'm thinking to close the hole in manifold that draw to PCV and i will replace the PCV with fitting that draw to the catch can with breather
    after this day no need for PCV
    jdoc7 is offline LX Newbie
    Feb 2009
    Central IL.
    Both mine go to catchcans, one with a breather
    2008 JEEP SRT-8
    CORDOVA DRAGWAY PARK
    10.91 @ 124.30 60' 1.499
    The "Elephant"/426ci/Whipple 2.4L (11 psi)/H2O-Methanol/Kooks LT/Corsa/PP Trans-TC/2800 Stall/FORD 9"-Wavetrac LSD/NT05R/6-pt. Rollbar
    DarthCharger's Avatar
    DarthCharger is offline Supporting Vendor
    Aug 2007
    Cypress, Texas
    Quote Originally Posted by jdoc7 View Post
    would you have pics of your solution? Having difficulty visualizing the setup.
    Sheldon@USWForged.com
    Check Out our Latest Wheel Designs
    Visit Our USW Forged Vendor Section
    713.680.8170 main
    2855 Mangum Road Suite B208
    Houston TX 77092
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
    BBoyPersia's Avatar
    Aug 2009
    Silver Spring, MD
    Quote Originally Posted by DarthCharger View Post
    instead of a filter going on the oil fill, you put a catchcan on it. the link i posted in the 1st reply is a basic one
    mdany's Avatar
    May 2010
    kuwait
    hope this solution will help
    any suggests ?
    Tim@NCTSLLC's Avatar
    Tim@NCTSLLC is offline Supporting Vendor
    Put a second straight through pcv valve in the line between manifold and stock pcv. Throw that filter away, attach a catch can off the vent line fitting, and attach other line off catch can somewhere between air filter and compressor inlet so you are always pulling vacuum through catch can. In 5 years have never blown oil like that.
    North Coast Turbo Systems LLC
    Home of the fastest 5.7 Cherokee, 13.39@104.62 MPH
    All stock internals 5.7 Hemi with a bolt on turbo, Tuned via the iEMS3
    Sharadon Performance Valve Body
    mdany's Avatar
    May 2010
    kuwait
    this drawing show u what i will do with this issue
    2 catch can one of them with breather
