So I've been running my 8 pound Vortech kit on motor with heads, cam, and a stock bottom end for over 6 months now. I've seen every supercharger kit produced toast at least one motor. I want to discuss some supercharger safety tips and tricks. Below is what has worked well for me. This is my personal experience and opinion, not any hard cold facts other than its worked well for me.
Blown motors come from 2 sources, heat and detonation.
HEAT: For those that don't know, compression generates heat and raises intake air charge temperature. You're motor then compresses all that hot air again, generating more heat. That heat then closes the gap on the piston rings causing them to go solid and pop off the ring land.
HEAT HELP: good tune, aftercooler, and water/meth injection (chemical intercooler)
DETONATION: With increased compression comes increased likelihood of premature ignition within the cylinder. These uncontrolled ignition events can easily break pistons.
DETONATION HELP: good tune (especially at part throttle), aftermarket fuel rails with front crossover and 3/8" fuel line if running 8 pounds of boost or more
I consider the aftermarket fuel rails and water/meth kit essential additions to stock bottom ends with boost.
Thats why I jumped on one the 1st chance I had.
