Intake Air Temps under boost???
Hey guys, trying to play catch up real quick here now that I have some boost to play with.
Curious as to what type of IAT/ACT temps you guys are seeing under boost. Can you guys post up what IAT/ACT you are seeing at what boost levels, what gear you were in when measured and what Intercooler/heat exchanger set up you are running?
My concern is that I am in dangerous territory.....and/or very limited in the timing I can run on pump gas due to the excessive heat in the air.
My setup:
GSM Novi 1500 6-8psi
GSM Intercooler with upgraded 2 core heat exchanger
IAT/ACT: +15-20deg above ambient at idle
120-130 deg at top of 1st gear
180 deg at top of 2nd gear
160-170 in 3rd gear (cooler water must be hitting the intercooler here)
What are you guys seeing????
Thanks,
Chris
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
