I was using E-85 on my Charger before my KB install and was happy with the results. Now that I have the supercharger I'm wondering what kind of boost everyone is running using E-85? Knowing your bottom end configuration would also be helpful.
Anybody???
I have seen some of the tuner cars running 35 psi. But it also depends on compresion ratio. You should show a big power change on e85 over gas on boost. Much better then N/A.
Having as much fun possible making power, with good friends
11.521@ 117.83 NA /11.007 @ 123.5 MPH N2O Stock cam and heads, diablo with DINGS CMR tune, 90mm TB, 373 gears, BB 4400 TC, (costom exhaust, CAI, ported intake manifold By DINGS), larger injectors for E-85, slicks, self made N20 kit and roll bar.
Running 50+ lbs. of boost no problem on 9:1 compression motors. Not in Hemis though. Doing 20-22 PSI on the Hemis no problem, but at that low of a boost level you really can run any fuel you want with the right tune.
www.EFISpecialties.com
EFI Tuning Specialist
Tuning the fastest, most powerful Hemis around
"In theory, there's no difference between practice and theory. In practice, there is."
