I don't know much about boost but would a GSM Supercharger kit for 5.7 work on a 392? Thanks Mike
Frank Racing Inc
6.1 431 Stroker ( Fully Coated shortblock set up for Boost, 9.6 comp,), 5.7 Exstream heads w .030 Mill, 2300 Harrop RDP Blower, FRI Camshaft ATI Over Drive Pulley,Labonte Motorsports Meth Kit, Little Nitros Kit, Dynatech Headers/Cats with a SLP LM2 , Pro Torque 3400 Stall, SRT Rear end w/ 3.06 Gears and DSS Halfshafts
490 HP and 455 TQ Before Motor and Blower Baby
Best Run to Date...
11.539 with a 1.599 60ft 4250 Race Weight at 117.58mph
Thanks to Steve AKA "Frank Racing", And Sohfast94! BAD A$$ Tuner
It will work but it's going to make minimum boost........maybe 4-5 psi
BFNY PERFORMANCE
RIP My Friend
Are you able to send in the compressors and "biggy Size it"?
Frank Racing Inc
Best Run to Date...
stu 5.7 392 stroker,sharadon heads, "The Embalmer" cam,whinning fan belt, dynatech headers, borla, 2800 stall, extra washer fluid, diablosport,huge c.c. bill, even bigger smile,
I think the confusion is that the blower head unit itself, and brackets, parts, etc. will all fit. The fuel system and engine calibration will not work.
Hemi31 has done this, and we have a car being finished up now with a GS kit (just the S/C related parts)
PM me if you need some help,
Ed
Sublime, given that the mounting parts/location is the same for 5.7/6.1 the only question you need to ask yourself is how much power are you looking to get out of it. In the end the paxton doesn't know/care what motor its on..... it will flow the same air regardless....determined by dampner/drive pulley sizes.
The GSM kit for the 5.7's typically came with the Novi 1200 which flows enough air to support 680hp, no matter what motor its on. http://www.paxtonauto.com/superchargers_novi_1200.html
Hope that helps.
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
roger that.
Do you need a S/C or do you have one, I have a Kit with the 1500 novi if you NEED one.
My Mods:
Procharger F1-C supercharger @ 15psi running thru a full custom ductwork including a Danko productions Shaker hood kit transformed into THE FAKER SHAKER you see today by 402 Motoring and a 24"X18"X4" air to air intercooler then to the throat of a single plane intake by XV Motorsports, 8.5:1 Comp ratio, H-beam rods, Ross racing pistons, P&P heads & intake, Diablo tuned by Dave @ B&G, complete return fuel system using a Weldon racing pump and pressure regulator, Methanol injection removed, Nitrous perimeter plate capable of 100-300hp (at 175 now), RUNNING 10'S ON THE DRAGSTRIP
I don't have one, but since my last two outings at the track I have been bitten BAD buy the raceing bug. My 5.7/392 isn't make the HP and TQ numbers some of the big guys are, and I was only able to make a 11.98 on my first time out, the secound time at Sealy (Henneys Track Houston) I broke my shaft on launch, but I have a sweet pic, Im trying to down load of my front tire comeing off the ground. Dyno only showed in bad wather, 410hp and 438 TQ at starting at 3,000rpms.
So I have some time, wateing for DSS to send me my axles, and Im trying to exsplore my options.
I want to be in the mid to low 10's, Yes Thanks to the help of some, Im in the proccess of getting a cage made.
Im wroking on a 350hp 2 stage shot set up, but Im not sure if thats going to get me there. And I saw someone sell there 5.7supercharger set up for $2500, so my mind is raceing, what to do next to get the numbers up.
Thanks Mike
Frank Racing Inc
Best Run to Date...
11.98 for the first time out????? Screw the numbers.... that is a great starting point. Just ask how many other strokers (392, 426 or any of them) hit 11's first time out. Bet you are in an exclusive club right there. While mid 10's might be a reach for the motor only combo, no reason to think there aren't a few .1's in refinement sitting there for you.
While I have never been a huge fan of the centri style superchargers in the past........let me tell you, that all changed this fall. That NOVI 1500 is capable of some crazy numbers.
Good luck.
Chris
Thanks. I still only have a mail tune, and FRI is in the process of helping finish my secret squire intake, and I just got my front runners thanks to Power Wagon. I took the car to shop for a cage, but I want to put it in the autoroma in Houston and there's no time. I can't wage for some cold air. I think I'm just going to foucse on my nitrous Thanks Mike
Frank Racing Inc
Best Run to Date...
I'm in the process of doing the Novi 1200 on my 6.1L as well, it should work nicely for me until I can upgrade my rods/pistons in the future. I just picked up some SRT-4 blue top injectors (stage 1), SRT-4 2 bar map sensor to allow for the additional boost. The last thing I need to find is the bolts as my setup was just the bracket, head unit and intercooler.
Mike & Tina & Kids
2010 Ford Flex Ecoboost V6 twin turbos
2010 Ford Mustang convertible V6 no turbos
