Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 91
Like Tree16Likes
Thread: Edelbrock E-Force Supercharger installed, time to give an update
  1. #31
    GRNMCHN's Avatar
    GRNMCHN is online now GRNMCHN
    Apr 2011
    Here is the time-slip:
    2010 Dodge Challenger SRT8
    Hemi Orange, TrackPak, 6 Speed, Sunroof, NAV, Subwoofer
    Mods: Edelbrock E-Force w/3.5" pulley, Magnaflow Cats, 392 Fuel Pump+BAP, BBK 85mm TB, Jet 180 thermostat, Diablotooner was here...
    RWHP: 510 RWTQ: 490 (Mustang Dyno) - 1/4 mile 12.2@122mph on stock F1's
  2. #32
    1FST4DR's Avatar
    1FST4DR is online now I just dont get it...
    Ft Laud.....
    Nice set up. I like the fact it has a dedicated belt for the S/C..
  3. #33
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    Nice 60.....Imagine what it would run if you could manage to get it off the line
    RIP NHDave
  4. #34
    1FST4DR's Avatar
    Ft Laud.....
    What PSI are you seeing? Nice set of D/Rs would put you right in the 11's for sure..
  5. #35
    Nov 2008
    Albany, IL
    Impressive. Can't wait to see how it does with a good set of tires and a solid launch.
    07 Charger SRT-8
    Procharger Stage II D1SC 8 psi
    Arrington dual fuel pump
    Ford 80lb injectors
    1/4 mile: TBD
    12.87 @ 108.83 CAI, 180 Tstat, 93 canned tune, street tires
  6. #36
    GRNMCHN's Avatar
    Apr 2011
    Quote Originally Posted by 1FST4DR View Post
    At the dyno today it showed a minimum of 4.8psi and a max of 5.7psi with an average of 5.2psi
  7. #37
    GRNMCHN's Avatar
    Apr 2011
    Here are the official numbers from the dyno today (remember Mustang dyno.)
    470hp and 440tq at the wheels
    peak boost 5.7psi
    This is with a tune from Johan (diablotoona), the canned tune from Edelbrock made about 20-25hp less.
    I will post the entire before and after comparison graph sometime tomorrow.
  8. #38
    1FST4DR's Avatar
    Ft Laud.....
    The blower has its own pulleys correct?
  9. #39
    SRT8U's Avatar
    SRT8U is offline www.speedlogix.net
    Jun 2006
    South Florida
    Great time! Nice setup.
    Kris | Mopar Specialist | Speedlogix, Inc.
    2006 Charger SRT8 Vortech Supercharged & 2012 Charger SRT8
    *** We Price Match - click here to see how it works! ***
    2011+ Hemi Tuning is here! Click for more info!
    Visit us online at Speedlogix.net or call 888-SPD-LOGX to talk to one of our Mopar experts!
  10. #40
    GRNMCHN's Avatar
    Apr 2011
    Yes, the system has its own pulleys.
  11. #41
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by GRNMCHN View Post
    Looking at the pictures the lower pulley looks like its an actual replacement for the balancer,How did that mount? I appreciate the answers btw. THank you.
  12. #42
    GRNMCHN's Avatar
    Apr 2011
    Here is the before and after graph from the dyno...
  13. #43
    whitehemi's Avatar
    whitehemi is offline Supporting Vendor
    Nov 2008
    Murrieta, Ca
    Not bad, not bad at all, the afr looks a bit lean to, 12.8? Is that 5.7 lbs of boost.. The 5.0 Mustangs are making some really good power with this set up when turning up the boost.
    6.1 swap......
    1.599, 7.46 92.18 mph 1/8
    4250 lbs
    "you're going to come across people in your life
    who will say all the right words at all the right
    times. But in the end. it's always their actions
    you should judge them by. it's actions, not
    words, that matter."
  14. #44
    GRNMCHN's Avatar
    Apr 2011
    Yes, Edelbrock supplies you with both a new balancer and pulley for the stock belt and the new secondary pulley for the supercharger. The first one gets press fit just like the stock one or any aftermarket UDP. However, you do have to drill the crank for a keyway button and they supply all the tools necessary, bit, reamer, and a tool so it drills in exactly the right spot. You then bolt the second pulley onto the one now in the stock location. It is mounted using something like eight small bolts around the inside parameter of the pulley. You can download the install manual on their website and it gives some really good pictures and information.
  15. #45
    GRNMCHN's Avatar
    Apr 2011
    Quote Originally Posted by whitehemi View Post
    Yes, that is 5.7 psi boost. It was funny. A Mustang fan at the track was "kind" enough to point out that his friend had the "exact same system" but ran 10s. Talking to his friend it turns out that he also was running 9psi boost, with slicks, and several other mods...LOL...sorry that is not "the same."
    Anyway, I am going to call Edelbrock to get some insight on whether or not they have any optional pulleys for this system. Maybe they do or they are the same pulleys as the rest of the units for other cars, 7psi might be in my future!
