Results 1 to 15 of 21
Like Tree1Likes
Thread: Changing from a 3.7" to a 3.4" procharger pulley....belt size reduction?
    BMWDON's Avatar
    BMWDON is offline I-495 Hater
    Dec 2004
    Southern MD
    So currently have a 111.5" gates on her, the circumference of the 3.7" is 11.62" and the circumference of the 3.4" should be 10.68". So if the belt rests on roughly 60% of the pulley circumference, I'd guess it's slightly .6" less overall path. But I'm not seeing a gates in 111", but see a 110.5". The dayco tensioner is sitting right at the midpoint of the gap for the alloted travel area for the tab. And I should have a little variability on the pulley on the procharger mounting plate too.
    So to recap, is changing the belt from 111.5" to 110.5" the probable right size when changing from a s/c pulley 3.7" down to 3.4"?
    Or is my thinking too small and I'm not considering enough variables in this?
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
    DarthCharger's Avatar
    DarthCharger is offline Supporting Vendor
    Aug 2007
    Cypress, Texas
    Subscribed. I would suggest contacting Procharger also but in my experience their customer service is not very good. You mentioed that the Dayco tensioner is sitting as recommended. If the smaller 110.5" belt is used, is this likely to reduce the travel of the tensioner to the point that it does not function as recommended? I am not sure how the 0.5" difference translates relative to the tensioner travel.
    How much more boost do you expect with the smaller pulley?
    Sheldon@USWForged.com
    Check Out our Latest Wheel Designs
    Visit Our USW Forged Vendor Section
    713.680.8170 main
    2855 Mangum Road Suite B208
    Houston TX 77092
    Arrington forged 392\ProCharger D1SC (11.20/124mph)
    BMWDON's Avatar
    Dec 2004
    Southern MD
    I've been told it should gain 3ish psi. That's why I'm thinking with the adjustable pulley that's on the procharger bracket will come into play, it's not maxed out at the moment, I've got a little adjustability in that too. I'd actually like to see the dayco tensioner just a little on the "tighter" side than dead center, not quite at 75%, but more like 60-65% or 5/8's of the movement availability on that tab
    Knuckles's Avatar
    Knuckles is offline LX Padiwan
    May 2009
    Chicago, Illinois
    Curious myself as I have a D1 with a 3.4" pulley as well..... Will check in the next few days to see what belt was included in the box.
    Check out this website below as they have a bunch of cross reference part numbers for belts. Then you can look up the specs on one part number above or below on the the current belt that you are using to help you find a 111" belt.
    http://crossbelts.com/serpentine/6ribkseries.html
    Jose---2008 Jeep SRT 8 SBM
    Mods: 4" Bwoody CAI/FRI Little Boy Cam/SLP UD Pulley/CORSA Exhaust/SW 1 7/8" Headers/Black Ops Ported intake manny/Arrington 90MM TB/Diablo Trinity/Diablotoona CMR Toon/Innovate XD-16 with LC-1/Jet 180* T-Stat
    BMWDON's Avatar
    Dec 2004
    Southern MD
    Thanks for the link, lots of useful cross belt info. Are you using a ATI dampner/OD pulley too?
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    Why aren't we just buying the belt and trying it already?
    Swap the pulley take a look at the tensioner and make a judgement call. There is no magic slide rule identifying exactly which belt for a given pulley combo.
    Stupid Nasty.... FBG 2.0 9.59 @ 148
    FBG 3.0 underway.... Arrington Aluminum 440/Vortech XX trim /4.2KB /Turbo/Nitrous testing in progress
    BMWDON's Avatar
    Dec 2004
    Southern MD
    pulley ain't here yet!! just ordered it yesterday First I get the gauges in so I can see afr and fuel pressure in front of me, then I change pulley and belt. I have both belt and pulley ordered, I hope to see them next week, maybe install the weekend of the 19/20th...probably not, but hopeful.
    Knuckles's Avatar
    May 2009
    Chicago, Illinois
    Quote Originally Posted by BMWDON View Post
    Anytime man! I will be using a stock crank pulley on my stock 6.1 block and will be running aroun 9 psi... I am with Hemi C though I would buy the pulley that I think should fit and then try it. if its too big or too small then decide from there on another belt.... Let us know what you find...
    SCOTT57RT's Avatar
    SCOTT57RT is offline LX Guru
    Jun 2007
    Jackson, MS
    Sent this over to bozo4. He's done a ton of pulley changes.
    SCOTT57RT
    2007 RT Charger 5.7L - Black Crystal Pearl
    Mods: DiabloSport Predator - InertiaTuned, MagnaFlow CAT Back Exhaust, JBA High Flow Cats, JBA Headers, 185Tstat, 85mm CNC Throttle Body, 6psi-P1SC Procharger Supercharger, R1concepts Slotted&Drilled Rotors, Blown Spartan Cam, 20x9 FR SRT8 Challenger Wheels/NittoInvo, Mygig
    bozo4's Avatar
    bozo4 is online now LX Padiwan
    Apr 2011
    I used the stock belt all the way to 3.5 making just under 9 psi.. Still had adjustement left.. Went from 3.5 to now running a 3.1 pulley with a 6pk 2790 belt... This belt just fits on.. I havent even adjusted the tentioner up.. I do run an extra idler pulley and dayco tensioner with this though.. Making 11psi.. Sorry I couldnt be more help..
    BMWDON's Avatar
    Dec 2004
    Southern MD
    thanks for the inputs guys, I'll let you guys know how the 110.5" fits after I get the other stuff (gauges) installed first and then put on the smaller pulley and belt.
    Knuckles's Avatar
    May 2009
    Chicago, Illinois
    Keep us posted man.....
    Knight is online now Mopar FTW
    Dec 2010
    Maumee
    Anyone ever come up with an answer? I am installing my 3.4 today lol
    [/quote]
    2007 SRT-8 Charger Group I, II, and III
    - SLP Loudmouth I Exhaust/ Procharged HO Kit 6psi/SRT Max Cam/3.91 Getrag Swap/3200 Dominator Converter/Ksport Coilovers/BT SRT Shift Knob/ 22x9 and 22x10.5 TSW Jarama Rims/Danko SRT Chin Spoiler
    BMWDON's Avatar
    Dec 2004
    Southern MD
    I swear I'm going to do this soon!!!!!
    Dec 2010
    Maumee
    Im doing this tonight. Ill take it around the block and give her hell. I'll update it lol.
    I DO however have an extra tensioner from DTP on my pro charger as well. So that may make a difference
    Knuckles likes this.
