Results 1 to 15 of 16
    tbyrne's Avatar
    tbyrne is offline Supporting Vendor
    Feb 2005
    www.tbyrneperformance.com
    ATI ProCharger - Difference Between Stage 1 and Stage 2
    HO Intercooled System
    The ProCharger HO Intercooled Supercharger System utilizes a "shared-drive" for the supercharger, and features the industry-leading self-contained ProCharger P-1SC-1 Supercharger, a large, 3-core air-to-air intercooler, upgraded fuel system and all necessary tubing and brackets. The 100 percent complete HO Intercooled system provides a standard 6 psi of intercooled boost when installed on otherwise stock vehicles. This is the package that most customers go with.
    Stage II Intercooled System
    Utilizing a proven and durable "dedicated-drive" system, the Stage II System also makes use of the proven and self-contained P-1SC-1 ProCharger Supercharger, while adding a unique, highly-efficient air intake and large, 3-core air-to-air intercooler and all necessary brackets and tubing. The Stage II Intercooled System provides outstanding power gains on both stock and modified engines with its standard 6 psi of intercooled boost and is best suited for future engine, fuel and exhaust system upgrades.
    ProCharger Systems feature easy installation, minimal relocation of components, no need to punch a hole in the oil pan, and avoids having to deal with the complexity and installation time and maintenance required for an air-to-water-to-air intercooler arrangement.
    ProCharger Tuner Kits
    In addition to the two 100 percent complete systems, ProCharger also offers two intercooled Tuner Kits – an HO Intercooled Tuner Kit and a Stage II Intercooled Tuner Kit. ProCharger Tuner Kits are essentially identical to the complete systems, but exclude fuel system upgrades and tuning. Both the HO and Stage II Tuner Kits are ideal for modified engines and are available with higher boost levels.
    5.7 owners can expect just over a 100hp increase can feel an additional 150hp!
    The intercoolers along with the unmistakeable sound of.... horsepower whistling under the hood will let your competition know what they are in for!
    Tom
    TBYRNE Performance LLC
    Fall River, MA - 1-877-482-9763
    Website -www.tbyrneperformance.com
    E-Mail - sales@tbyrneperformance.com
    Performance parts sales and installation. Window tinting, remote starters, electrical problem diagnostics plus much more!
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    how do the stage 1 and 2 differe in performance?
    have any shots of the stage 1 intercooler?
    i like the positioning of the stage 1 head unit more... pretty good air feed from the chally or charger air ducts in the hood... but the intercooler in the stage 1 looks like it has a wierd airflow...
    can you show how the air is actually travelling with a full shot of the IC? is the chally picture below the stage 1 or 2 IC?
    joessrt8's Avatar
    joessrt8 is offline ROOOOAR
    Oct 2008
    Modesto, California
    Quote Originally Posted by dudeiwin86 View Post
    I have the stage 1 kit and the picture of the challenger there is the same intercooler I have.
    ProCharger P1SC1 Supercharger @ 6lbs Boost, Modified ProCharger Tune, ProCharger Boost-A-Pump, 65lb Fuel Injectors, Kooks Coated Headers & HF Cats, Magnaflow Cat-Back, CompCam 268, BT Catch Can w/Fender Mount, 180 Degree T-Stat, CNC Ported Throttle Body, ATI Super Damper 5% Overdrive, DiabloSport Programmer, Mopar Front Strut Tower, Razors Edge Rear Arched Strut Tower, Pedders Bump Steer Kit, Upgraded 09' R/T Axles/Hubs, Front Nitto NT555 275/35/20, & Rear Nitto NT555R 305/35/20 Drag Radials.
    STD Numbers: 537 RWHP - 476 Torque
    http://www.youtube.com/joessrt8
    AlbertaCharged's Avatar
    AlbertaCharged is offline Destroyer of Tires
    Jan 2009
    Innisfail AB
    Why isn't there an option for the stage II kit on your website? I have been looking into these kits, but there is only the HO kit option on your site and even that only with the combination with the gauges and torque convertor. I don't much care for the shared drive or the position of the air intake in the HO system. Could you PM me the pricing for the kit?
    Thanks,
    AlbertaCharged
    BMWDON's Avatar
    BMWDON is offline I-495 Hater
    Dec 2004
    Southern MD
    how much is the complete stage 2's?
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    10.89 on Nitto Invo 315/35x20's @18psi in tires. 1.589 60' too! http://www.youtube.com/watch?v=KeXYxSCI_8A
    flpaul's Avatar
    flpaul is offline procharged srt8 charger
    Aug 2007
    Boynton beach Florida
    i have stage 2 in my charger it uses a cog drive system it is not ran by the stock belt drive u have to put a ati crank dampner to put prochrgers pully on, go on youtube.com and search superchared srt8 the black one is mine u can hear the procharger it sounds bad ass,
    Jan 2009
    Innisfail AB
    That's one badass setup you have flpaul. But where did you get your package? Like I said i've been looking for the stage two, but can't seem to find any vendors with this package. They only seem to carry the HO.
    2007 Charger srt-8 zex nitrous with N.O Plate, LMI frankentake, JBA exhaust with magnaflow high flow cats and mids, Predator etc..
    2000 GMC 2500- 6L vortech... pretty much stock
    2007 Kawi Mean streak 1600cc - mod list is stupid
    Thanks to : BMC, Billet Tech, Nitrous Outlet
    flpaul's Avatar
    Aug 2007
    http://www.lethalperformance.com/ talk to jonis
    1 877 2lethal
    tell him u are a friend of paul
    more pics on myspace.com/paulne
    CJR300C's Avatar
    CJR300C is online now Bagged, Dragged, & Blown!!!
    Feb 2007
    Grafenwoehr, Germany - Currently Afghanistan
    That is a nice system! I'm about a month away from picking up a s/c. Those are some good pics of the Stage II on your myspace page, most of the pics I've seen was for the Stage 1 system. Is there a boost difference between the two? Like is the Stage II a 8psi or the 6psi? The Vortech is my first choice, then is the Procharger system. The Procharger might make the number one spot for me.
    Quote Originally Posted by flpaul View Post
    1 877 2lethal
    flpaul's Avatar
    Aug 2007
    7psi right before it red lines cant go any more i already blow up the motor got really bad gas,
    i will sell my stage 2 with every thing for 5000
    vortech kit is a hell of a lot easyer to put on
    deathtrain is offline Deleting Posts is Lying to Customers.
    Nov 2006
    so are you switching over to the vortech system?
    flpaul's Avatar
    Aug 2007
    no trading in car on 08 i think not going to do any thing to next one i have a mustang for that
    http://www.youtube.com/watch?v=AEXZZsNUKQg thats my car
    Wetcoast's Avatar
    Wetcoast is offline Pulley, HX in possession!
    Langley, BC
    How much was it new?
    4drvet!
    flpaul's Avatar
    Aug 2007
    6500 with out tune and that includes the meth
    MoparBot's Avatar
    MoparBot is offline Lurker Supreme
    Feb 2009
    Glenside, PA
    So does the Stage II mean less parasitic loss to the wheels with the "Dedicated Drive" system. So at the same PSI it creates less HP loss where it matter meaning more street HP?
    and do you have any pictures of the entire system uninstalled (cooler included) and a picture installed with the front bumper off? Not a lot of good pics available for this kit. great info here though...
    Edit: found an stg1 intercooler pic at Modern muscles site.
    http://www.modern-muscle.com/albums/Ugoh/PB240181.JPG
    i like this design a lot. only thing that i don't like is the intake tubing in the back of the housing. it sits way into the engine bay. with that size IC it shouldn't be a problem, but the more cold air the better ya know? i assume the stg2 is just about the same set up? curious to see how it looks exactly.
