Results 1 to 13 of 13
    leveil22's Avatar
    leveil22 is offline Leveil24
    Jan 2008
    San Antonio,Tx
    Any MPG Gains From Meth
    Was wondering did anyone see gains from adding meth?
    The Boss : Supercharged 3.5 V6 too many mods to list just have to see it person.Member ACLX Club as you can see we don't play around out here.!Update! Soon to be loaded with Inertia Racing Heads and Cams! AE Carbon ported lower intake and TB!(Installed) !New Dual Sunroofs! (check out my post)
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I know guys with the Cummins diesel Rams claim 2-3 mpg boost, but gas motors would get a smaller gain. I ran water meth on my old Toyota Tacoma 3.4 V6 and mileage was really bad, but at least the spray kept it from destructing.
    srt-hardware's Avatar
    srt-hardware is offline Fast is the game
    Jan 2007
    Upstate NY
    will be no gain since it is only used at high boost.
    It is an octane booster and intake charge cooler. It only helps to overcome the limitations of a gas engine under heavy load.
    There is no need for it at cruising situations and therefore no gain.
    Don't forget there is a cost to buy the meth and 1-2 mpg will not cover that cost
    My Mods:
    Procharger F1-C supercharger @ 15psi running thru a full custom ductwork including a Danko productions Shaker hood kit transformed into THE FAKER SHAKER you see today by 402 Motoring and a 24"X18"X4" air to air intercooler then to the throat of a single plane intake by XV Motorsports, 8.5:1 Comp ratio, H-beam rods, Ross racing pistons, P&P heads & intake, Diablo tuned by Dave @ B&G, complete return fuel system using a Weldon racing pump and pressure regulator, Methanol injection removed, Nitrous perimeter plate capable of 100-300hp (at 175 now), RUNNING 10'S ON THE DRAGSTRIP
    MikeEast's Avatar
    Ducktown, Georgia
    The only time my meth controller lights up the pump is under heavy load and significant rpm - not gonna see any mileage gains there I'm afraid.
    Kinda cool seeing the green LED come on though...
    Mike
    Redfox0099's Avatar
    North Charleston, SC
    The only gains I saw on my NA motor was it allowed me to run 87 octane on my 93 tune while making long cross country trips where no WOT was needed, it just let me buy cheaper gas.
    Posted via LXFMobile
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    Hmmm I tell you since my Meth comes on at 3000 RPM and WOT so that is an good indication that my mpg will be steadly going downward at a pretty good rate.
    N/A ET 10.44@128
    Joy ride TT Challenger 9.71@143
    7.5L Aluminum Block 460 N/A 635RWHP\650RWTQ By Lewis Performance Machine
    Quote:
    Originally Posted by Jack SickSRT
    Bring what you got, run it and STFU!
    leveil22's Avatar
    Jan 2008
    San Antonio,Tx
    thanks for the info
    SKULLBOY's Avatar
    SKULLBOY is offline Veritas Aequitas
    In A Bunker......
    Quote Originally Posted by MikeEast View Post
    Mike
    X2 !!!!!!!!
    HEMI Registry #1575
    CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
    leveil22's Avatar
    Jan 2008
    San Antonio,Tx
    Where can I find low voltage side of primary ignition coil
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    Anybody have an IAT sensor mounted where it can see the difference meth makes? How many degrees does it cool the air charge?
    I'll keep my money, guns, and freedom, you can keep the change.
    MikeEast's Avatar
    Ducktown, Georgia
    Quote Originally Posted by Maistro69 View Post
    I moved mine up by the air filter a long time ago, but that would be a cool thing to find out about...
    Mike
    Nov 2007
    I'm not sure very many people actually have them in the right spot to measure IAT's with a blower. N/A is easy but it's a whole new ball game with FI, especially PD blowers because it has to be in the intake itself. I've got my alky kit thanks to Eddie at SHR just curious what to expect in temp reduction
    351Freak is offline Supporting Vendor and Enthusiast
    Jan 2006
    Dallas, GA
    Quote Originally Posted by leveil22 View Post
    low voltage side is the 2 wires going into each individual coil.
    the coils use switched ground...so each coil should have 1 wire that is the same color for all coils...and that should be the +12v...the other wire is the switched ground and typically has the better signal for tach pickup...your results may vary...
    -Freak
