Results 1 to 8 of 8
    JBs_300c is offline LX Padiwan
    Aug 2007
    alabama
    90mm tb + procharger?
    while im waiting for my srt challenger to be here i was thinking about going ahead and gettin my mod list together i wanna spend about 10k but need to be able to do most of the work myself. i dont really feel comfortable going inside the engine or even doing full longblock swap myself so im kinda learning towards a procharger. my question is how should a ported intake and 90mm tb help the gains of the sc? car will also have a full exhaust on it just wondering more about the gains on those two mods + boost
    *edit becuse i suck at spelling
    HULK's Avatar
    HULK is offline West Coast Style Meets East Coast Power
    Aug 2007
    Chicago, IL
    OK, I had the whole 90mm TB and supercharger thing explained to me by a vendor here, so I will do my best to explain what he said when I asked about it...
    Originally, I thought just like you did in that the two products would be a wicked combo. However, a vendor (who actually retails the 90mm TB) informed that a TB really wouldnt be that much more effective than stock because with a supercharger on hand, air is being FORCED in. So it really doesnt matter how big of an opening its going into because the same amount of air is still being pushed in.
    However, without a supercharger, air is being SUCKED in, whcih is where the TB is supposed to be the most effective.
    Follow me? And this vendor is a retailer of both products, so for him to tell me that it really wouldnt be that effective means he was shooting straight from the hip and beign honest about it.... not just trying to make a sale ont wo products, like he could have.
    Hope that helps and it sounds clear to you.
    -Pat
    Quote Originally Posted by Simans82 View Post
    Compared to your modding addiction, I'm just looking at the coke on the table. You on the other hand, you're more like Scarface.
    Aug 2007
    alabama
    what about ported heads and intake? im sure the heads would make more power but im thinking the intake would be kinda like the tb idea. thanks for the info tho that makes a lot of sence now that i think about. i've never had a s/c car before so i really dont know what to expect on what mods would help or just be there not doing anything any input on this build woud very helpful
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    If you are saving your pennies and want to do it right, buy a forged short block and then supercharge. This will allow you to do it right and not be restricted by the stock pistons.
    The price of the throttle body, heads and ported intake isnt much different than a forged 6.1 bottom end and I think it is cheaper.
    8yourM5's Avatar
    8yourM5 is offline Northern CA
    Sep 2008
    Buid a low compression 426 then get the supercharger later that what I did
    hemidup is offline Giddyup!
    Nov 2006
    Minnesota
    Forget the 90mm throttle body. The output diameter of the blower is your restriction.
    My name is Jerry Williams. The Grandaddy of Gen III Hemi Performance
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by hemidup View Post
    Again... every point in a fluid's path of travel is a restriction. It's additive, not a "bottleneck" scenario. Increasing the throttle body diameter will allow more air to reach the valves. Now, if the valves are already getting more air blasted to them then they can let into the engine, that would be your "restriction." But more pressure behind the air will mean more air flow.
    srt-hardware's Avatar
    srt-hardware is offline Fast is the game
    Jan 2007
    Upstate NY
    Do like FlybyU said. Forge the bottom end and change the cam. Dollar for dollar it is the safest and the highest ratio of power you will get. The supercharger will compensate for all intake restrictions nothing else needed. Ooops, free flowing exhaust is real important.
    My Mods:
    Procharger F1-C supercharger @ 15psi running thru a full custom ductwork including a Danko productions Shaker hood kit transformed into THE FAKER SHAKER you see today by 402 Motoring and a 24"X18"X4" air to air intercooler then to the throat of a single plane intake by XV Motorsports, 8.5:1 Comp ratio, H-beam rods, Ross racing pistons, P&P heads & intake, Diablo tuned by Dave @ B&G, complete return fuel system using a Weldon racing pump and pressure regulator, Methanol injection removed, Nitrous perimeter plate capable of 100-300hp (at 175 now), RUNNING 10'S ON THE DRAGSTRIP
