Results 1 to 15 of 23
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    6.1L x 12psi = 625/595 and 10's @ 128+
    Hey guys just checking in with a quick dyno pull and some track times with the new combo.
    After owning the car for a few months I managed to sort things out fairly well over several trips to the track, setting the 6.1 Power adder record Of course the proud father (Hemi31) couldn't have been more pleased.
    However, several issues crept up.....some of them self induced.
    1st the original water to air aftercooler was causing IATs to go through the roof..... so I moved to a front mount air to air...problem solved.
    Then I decided to do some math and realized I was leaving something on the table with the 3in drive pulley on the Novi 1500. So like any other maniac I put the smallest pulley that would get me to the 58,000 rpm redline associated with the S/C given my 6200 shift points. I ended up with 2.62" pulley and a ****-ton more low/midrange torque (self induced problem).
    Which brings up the next two problems......first I was running out of fuel by 5000 rpms. By running out I mean, pump couldn't hack it and my SRT4 stage II's are out of fuel. So, I dove in and redesigned the stock set up to take a second pump, provide more volume@higher pressures, but retain stock type fuel return/enclosed basket design.
    Problem solved through increased volume but bigger inj are still going to be necessary.
    Needless to say Lafrad handled all the tuning duties with ease......over email.
    Now while I was solving all my other issues the internals of the tranny were quickly being reduced to a burnt up slurry of metal goo at the bottom of the pan. After four track sessions, numerous street miles as a daily driver the clutch packs finally gave up and I had to limp mode home @ 35mph for 17 miles through downtown D.C. So.....on to tranny number two. Original tranny now being rebuilt again, my replacement tranny is already showing signs of fatigue. Fixing this has become priority number one. Two possible solutions.... 1st and cheapest will be to reduce power on the shift either in the tune or modulating the boost via vac solenoids (more to follow) or squirrel away some money for a real tranny that can hold the power being produced.
    It is worth noting here, that in an effort to improve the shifting situation I upgraded to the MTCM which gave me an instant 2-3mph due to increased holding power. From there I upgraded to the B&G TCM, again another solid increase in holding power on the shift but at this point the internals of the stock NAG1 are not up to the task. Still seeing massive slippage on the 2-3 but much less on the 3-4 than before. 1-2 is rock solid.
    So with everything except the tranny sorted out it was time to get back to the track for some boost only runs to see how the car likes the new fuel/iintercooler/fresh tranny. Running in some real nice air the car responded rather well.
    Best run of the day was a 10.76 @ 127.43 on a 1.63 60'.....backed up by no less than 9 more 10.7 to 10.9 timeslips all in the 126-128 mph. Boost only, 4450 race weight. They shut us down to 1/8 for the last run of the day due to track conditions.....but I managed to squeak out a 1.55 60' on that one (thanks to FlybyU for his Hoosier hand me downs ) Of course all that had me thinking hmmmmm solid 10's on boost....I wonder what that 125 shot would do for me.
    Brought the car up to Atco for the last racing event of the year....hoping to throw a bit of juice into the mix. Unfortunately track conditions reduced Atco to a virtual ice skate rink for most of us. First run was a spin hook, spin, limp mode. 2nd run, spin through 1st/2nd...hit the juice a a couple secs in 4th once it was hooked up... 12.20 @ 129mph . Last run of the day, still came out spinning to a 1.84 60', 10.83 @ 129.59. No joy.
    Sooooooooo, today I managed to get a few long over due dyno pulls finally (you happy Erik?). Overall, I am pleased with the numbers given the heat soaked condition, but as you can see from the curve the tranny wasn't feeling it. Car was fighting the dyno the whole way. I picked up some hp/tq from shutting the ESP fully off via the pred but still seemed to be some tc lock or possibly slippage issues during the pull. AFR were mostly in the low to mid 10's......however the cloud of raw fuel in the air was burning out eyes so I think its safe to say I can still pull some fuel out. No doubt a full dyno tune is in this car's future.
    Results 625rwhp / 595 rwtq, ambient air aprox 70deg, IAT ranged from 85-120deg. We tried a N2O pull but the engine became very angry.....massive KR, reducing timing to 7 deg at WOT, car fell flat so we let out right away. I think I heard it say more octane please.
    Lastly, it would be a crime if I didn't thank you all for the help/advice/sanity checks over the last few months. Stay tuned...more to come.
    Stupid Nasty.... 9.59 @ 148
    PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
    Redfox0099's Avatar
    North Charleston, SC
    You got a B&G TCM..is there a write up on it? What all did you get done with that and your thoughts on it?
    HULK's Avatar
    HULK is offline West Coast Style Meets East Coast Power
    Aug 2007
    Chicago, IL
    Good info and write up!
    I think its great that you are documenting everything so well as you go along. Granted, the car was set to haul ass from the start, it gives people that much better of an idea to see what you are up to at this point to make her keep going...
    Keep up the great work! Id love to see what a built SHR trans, a perfect CMR tune, and this motor could do on the track on a good day!
    -Pat
    Quote Originally Posted by Simans82 View Post
    Compared to your modding addiction, I'm just looking at the coke on the table. You on the other hand, you're more like Scarface.
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Nice write up Chris, it has been fun watching you get to this point.
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    Chris, I just pissed myself when I realized at 3600rpm you make more HP and TQ then I do at PEAK!
    Awesome...just awesome
    chess's Avatar
    chess is offline I make it rain....
    Jan 2008
    Southern MD
    Chris,
    You da man !!
    RobAGD's Avatar
    Reston, Va
    Nice to see that beast on the dyno, and yea I think that Trans is just not happy at all....
    I know you will get it beat though.
    -R
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Chris, it's been interesting to see the beastly Mag go from Erik 's hands to yours and the journey has been bumpy to say the least. You are a pioneer and I'm sure that we will be seeing some 9 second slips next spring! Kudos to you and Erik!
    John Y
    Trojan's Avatar
    Mar 2006
    So Cal
    Nice write up Chris, Always interesting to hear the latest on your build, Gonna be insane when you get the tranni dialed in!
    Jim "Meister" Edwards
    RIP "SLICK"
    rander's Avatar
    rander is offline Just trying to make it in this world
    TX
    Shame on you for pissing on yourself like a little girl lol! J/K...
    Aweseome results Chris! Just amazing. Erik, can't believe you sold that beast
    Quote Originally Posted by PaCharger View Post
    Mine: 2012 Dodge White Charger SRT8 6.4
    Wife: 2012 Jeep GC Overland with Hemi
    Sold: Black 2012 Dodge Challenger SRT8
    Sold: Silver 2008 Jeep Grand Cherokee SRT
    Sold: 2006 Dodge Charger Daytona modded
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Chris I am really happy you got it on a dyno.Knowing how dyno shy that car is I know there is more in it waiting to be coaxed out.Congrats.....can't wait to see it with a happy transmission.
    BFNY PERFORMANCE
    RIP My Friend
    Flanman's Avatar
    Flanman is offline I'ze done been Stu'd
    Dec 2005
    Northern Illinois
    You've put a lot of hard work in getting that car to where it is. Great work by you and Mike, and congratulations on the great numbers.
    '05 Magnum R/T-Inertia 407" stroker
    '70 GTX 440-6 (Needs resto)
    '66 Belvedere (Project car)
    '10 Ram 1500 Laramie Crew Cab 4x4
    Quote Originally Posted by Cam View Post
    I just happen think different then most sometimes.
    BuilderBill's Avatar
    BuilderBill is offline Supporting Vendor
    Feb 2007
    Yep...well done Chris.
    Call Eddie or I when you are ready for the tranny.
    I know it is expensive....especially in this economy.
    Bill
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    Great write-up and congrats Chris!!!
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    1FST4DR's Avatar
    Ft Laud.....
    Very nice write up for sure.Thanks
