Need to get larger injectors to get a good custom tune on my S/C 3.5 I found a set but I need to know will they work
guess I'll stick with these
Really dude, only way to figure out if an injector will work is to get the measurements, and look it up,
Or get the injector, and see how it would install. You are a groundbreaker as-is.. so you are paving the way for others...
The 5.7 injector may very well be a smaller injector than the 3.5 stocker.
I would pull one of your stockers and post up a picture of it so people can see it.
You may well be able to use some of the SRT4 inectors or some of the others that are around.
When your the first guy on the bleeding edge you have to do some of the research to fix stuff.
-R
